Maytag top load washer
Makes a load whining noice during the spin cycle - got any suggestions? Also, how do I take off the front panel
  • 639 Answers
Belt could be worn and screaming
Posted on Sep 02, 2008
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Whining during spin cycle
zato2
Could be a loose belt, or drum bearings,or ( drum rollers if your model is so equiped) In my mind machine would be worth repair when needed.
hope this is helpful
handiman518
Jan 17, 2008 | Maytag MAH6500 Neptune Front Loading...
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
