Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
No rear spark, put on new coil, new plug wires and new crank position sensor, still only running on front cylinder.
  • qweenjules Sep 03, 2008
    I have fuel injection so I don't have an ignition module (that's what I was told), but thanks anyway. Any suggestions is helpful.
    Julie
  • gwalkerides Feb 05, 2009
    no front spark
If you have an injected bike and it uses an ecu for engine management, it could be that the output transistor or driver circuits in the ecu are bad. if you are sure the rear has no fire that is probably that or if you have twin injectors, it could be a bad injector if you have fire. i assume you have a single fire ignition so you can perform this simple test. both plugs out, pull connector for coil, use jumper wires to connect back to the coil except reverse the wires for the cylinders, roll engine over and observe plugs, if the cylinders switch, then you need a new ecu. this is if you made sure wiring is ok first.
Posted on Sep 07, 2008
I had almost the same thing happen on my 03 sportster it was the ignition modual dont know what year yours is but 03s are bad about messing up harley said they fixed the problem on the replacements
Posted on Sep 02, 2008
No spark to front coil pack
Judging by your question you have automotive experience though for safety sake I will have to state some precautions anyhow. With the engine running and in park with the emergency brake set. Check your working coil packs "hot" wire with a multi meter. Set to 12 volts and check amperage and volts delivered. I would recomend checking each of the working cylinders if possible to establish base line readings. If you are receiving similar readings on the down cylinder then you have a short in the coil pack and it will need replaced. If you are not receiving a similar voltage and amperage you likely have a short and should trace the feed wire for that coil. As with all repairs if you are not absolutely sure of your capabilities to fix the problem you should seek the help of a professional. Happy motoring.
Mar 15, 2016 | Cars & Trucks
I have no plug wire spark 1997 dodge average 2.5 v6 24 value.have already replaced crankshaft positioning sensor on it and still no spark to the wires
Sounds like a bad distributor. Had you pulled a spark plug out you may have found them wet with gas after cranking. If they are wet the crank sensor is working since both injector pulse and coil pulse rely on crank signal.
The distributors are known week points in the ignition system and used to be common when theses cars where still on the road. A reman will run you $250 U.S.
Apr 05, 2015 | 1997 Dodge Avenger
P0302 mis fire, lacks power
Pull the spark plug of cylinder 2. Put the coil on the spark plug. Ground the sparkplug and have someone crank the engine. See if you see a spark. If you have no spark switch coils with another cylinder. If still no spark it could be one of the wires going to the ignition coil. If there is a spark do you smell gas at the spark plug hole? Could be no fuel to the cylinder.
Apr 22, 2014 | 2008 Ford Escape
2002 harley electra glide front spark plug turns black
A blackened spark plug is a sign of a rich air/fuel ratio or a misfiring plug. You stated that you changed the coil and wires, but did you change the plugs? Spark plugs, even new ones, can, and do, go bad (excessive internal resistance). Make sure that the plugs are also the correct part number for your application, as they could be of the wrong heat range for your bike. I have even heard of guys using a colder plug in the rear cylinder and a hotter plug in the front cylinder because the front cylinder tends to run a little cooler than the rear (increased air flow in the front).
Apr 09, 2014 | Harley Davidson FLHTCUI Electra Glide...
Cylinders 1 and 3 misfiring on 2.4 Liter 97 chevy malibu
code p 0300 is random/ multiple cylinders ----misfires detected ===causes ---spark plugs ---HT lead/s---injector/s---ignition coil/s---low compression---wiring
he has changed a lot for nothing
a 5 year old engine can have a lot wrong with it --so new out of a crate is no guarantee
most misfires are from injector problems
it could be a loose valve seat insert so have a compression test done if moving the injectors to new locations doesn't move the misfire
Apr 19, 2017 | Cars & Trucks
2009 electra Glide Classic rear cylinder doesn't spark its not the coil or wire
Hi D, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially "GROUND" cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below. Good luck and have nice day. Harley Diagnostic Codes 04 to Present
May 24, 2012 | 2009 Harley Davidson FLHTC Electra Glide...
I have a 2005 cysler 300C hemi 5.7. Ho do i find the crankshaft position sensor and How do I determine which cylinder is #1 and #7? I recently changed all coil 8 coil packs and 16 spark plugs. I have a...
Hello! See diagram below of the location of Crankshaft Positioning Sensor (CPS)...It has a 3 wire connector with the following wire colors...Dark Blue/Dark Green (ground)...Dark Blue/White (signal lead)...And Pink/Yellow (+5 volts)...
Looking at the front of the engine...The left bank (front to rear) are 2, 4, 6, 8...
The right bank (front to rear) are 1, 3, 5, 7...Therefore the first cylinder on the right bank is # 1...The rear or last cylinder on the right bank is #7
Guru...............Saailer
Sep 30, 2011 | 2005 Chrysler 300
No spark to rear cylinders runs good and then runs on one cylinder 1986 honda shadow 1100
try switching the position of the two coils, the plug wires will unscrew off of the coils and that way you dont have to pull the spark plug wires too,(be sure and change the 2 wire couplers too) if your front cylinder stops firing you know its the coil, if the back cylinder still doesn't fire then your coil is good and you either have a bad #2 spark unit or a bad crank pulse generator.
Aug 05, 2011 | 1998 Honda VT 1100 C Shadow Spirit
1984 Honda vt 500 no spark rear cylinder
Hi, Fjames855 and the usual suspects are:
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Rear Cylinders No Spark
Testing Honda Coils and CDI boxes
Honda VT500C Shadow Service Manual English pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT600C Owner Manual
Mar 20, 2011 | 1984 Honda vt 500 ft ascot
I have a 1990 fxr with a single fire ignition, cam and s&s carb. I am not getting the rear cylinder to fire. I just cahnged the coil but no change. I have compression out the exhaust pipe for the rear...
With a single fire ignition, you cannot swap the wires. A dual fire ignition, yes, but not a single fire. You need two things to get the cylinders to fire, spark and compression. Take the plugs out of both cylinders. Run a compression test on the rear cylinder. You need at least 100 PSI to get the cylinder to fire like it should.
Next, put your plugs in the wires, (they should already be in the wiresand grounded) and spin the engine over. Watch for the plugs to spark,especially the rear plug. If you have spark and compression it should run on the rear cylinder. If it still doesn't run, either something is way wrong with the ignition or a very bad air leak on the intake.
If you don't have spark at the rear plug, you need to check the coil. A single fire coil is different from a dual fire coil. The primary wiring is different as well. If you've got the primary wired incorrectly, you won't get spark at the rear plug. Go to the website of the manufacturer of your ignition system. Most of them have downloadable installation instructions. Check your primary wiring.
Oct 02, 2009 | Harley Davidson FXDL Dyna Low Rider...
Lands Phones Logo
266 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
