Question about Bosch Dishwashers
The countertop gets hot when the dishwasher is run. Is this normal?
  • 706 Answers
Built in dishwashers use very hot water for the wash cycle and have a heating element that can be selected for the dry cycle.. All dishwashers have some insulation wrap around the housing ( some more than others) and the fact that your counter gets warm is of no consequence.. In other words, I wouldn't be concerned over it..
Posted on Sep 01, 2008
Steam is pouring out of the top right hand side of the dishwasher. It is ruining the underside of the countertop.
Its completly normal for the dishwasher to steam during the cycle. Some manufactures make a steam guard which is a piece of stainless steel and mounts to the underside of the countertop where the dishwasher is installed to prevent the steam from ruining the countertop. If ya can find a piece of stainless steel to mount there it will deflect the steam.is needs to be stainless since regular steel isn't stainless and would rust over time. Perhaps plexiglass would work too.
Gene
Aug 04, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
We have a Bosch SHE45M06UC/50 in an island with a granite countertop. It is not attached and so moves. How do we attach it to the granite countertop? Or how do we attach it????
You glue on a wood strip, to the underside of the counter, then screw into that. Use construction adhesive. The wood strip needs to stick down no further than the counter edge treatment, so you normally cannot see this wood strip.
May 11, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher just started foaming really bad. And leaving lots of white residue. It has never done this before. I run finish detergent and just ran 2 bottles of cleaner through it and right away foam and...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Danby DDW497W 22 in. Countertop Dishwasher
Water not draining
The first thing I would check is the air gap. That is a silver or chrome thing on your countertop above the dishwasher. You can normally pull it off or twist it off. Look fore a plug. I have seen even a piece of popcon plugging it. Next check your drain line. If it goes into your garbage disposal make sure it is clear. Too many people do not run the hot water near there dishwasher before it is hot and then start the dishwasher. Todays dishwashers use very little water per EPA but need hot water to do the job.
Hope this helps
Sep 12, 2010 | Frigidaire 24 in. PLD3465REC Stainless...
On model du81qdwgq1 is hot or cold connection
You are supposed to connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water.
Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has been shut off for a while. If you have questions, please let me know. I hope this helps you.
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Installing a under the counter dishwasher
The dishwasher doesn't have to be between cabinets, but it does have to be enclosed on both sides, and it can't support the countertop. You can put an end panel there, which is just a finished panel with trim on the front to match the cabinets. Make sure it is straight and securely attachedd to both the floor and the countertop. Also make sure that you can route the water and drain lines out the other side.
Sep 28, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
GE built in dishwasher
YOU ARE UNDER WARRANTY SERVICE FOR ONE YEAR!
And if your a week over or a little bit, GE will still make good on it! Do not wait! Monday call GE! Why is it $200 for service call?
$75 is what we pay!
look for a new guy if they want here in fixya.com are service people,
too! Don't run this. it is a fire hazard if it's doing this!
Bless you
Aug 04, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
247 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
