Question about Sony LBT-XGR600 CD Shelf System
Search to datasheet stk442-130
Can you help me to find datasheet to ics stk 442-130 beacause it not found here i want to find ics equal it thanks
  • mohsen2233 Sep 01, 2008
    can you help me to find datasheet to ics stk 442-130 beacause it not found here i want to find ics equal it thanks
Cxd9841p datasheet sony
You can find a datasheet by searching for CXD9841P although that probably is a proprietary number
Jul 30, 2013 | Electronics - Others
One channel ceased to work. Found transformer to be bad and replaced it. Turned unit on and the top circuit board at front off unit was getting hot and a burnt odor appeared immediately. Found a...
The part is a 4560 (generic opamp IC. The damaged IC is more likely to be the symptom not the cause Remove the IC and the cap. Replace the cap, but not the IC and measure pins 4 and 8 to ground. These should be the power inputs and measure +/- 5 thru 12 volts. They should be equal but opposite. Should htey be different, check the power supplies or any filter caps.
Update this with the results.
Thanks,
Dan
Mar 22, 2011 | DBX 2231 Home Equalizer
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
One channel is out / no sound
Here you go.
IC101 STK412-020A HYBRID IC
Yvan
Dec 20, 2008 | Kenwood VR-406 Receiver
STK IC CHIP 392-110
I made the same repair in a Toshiba 42h81 I replaced the STK 392-110 and after a lot of searching found the cheaper ones last 6 month or so be sure to use Sanyo IC's and replace the resistors with them when the IC's let go they take the resistors out I posted my repair On my page if it will help you dennisgm052.weebly.com
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
MT42PZ10 LG plasma
I have the ic in stock,, it is 69 dollars.
Aug 19, 2008 | Televison & Video
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Sony LBT-XGR600 CD Shelf System Logo
675 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
