Question about Dryers
Replacing a belt on bosch dryer
How?
  • hellfish Sep 03, 2008
    I have a Bosch 4410 dryer and can't figure out how to open it up to get a new belt installed do I open from the front,back,bottom????
  • 639 Answers
Friend,
ngfam1 At your service!
You have a top of the line dryer! Why would you want to leave this to factory service to do it right! ??????????????
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Sep 02, 2008
On my Bosch Axxis condensation dryer model WTL 5410, how do I replace the blower belt part #00154142?
Go to www.repairclinic.com and enter WTL 5410. You will be presented with a list of common replacement parts and may be able to view a generic Bosch video showing disassembly and parts replacement.
Dec 18, 2016 | Bosch Dryers
Bosch WTA2000 tumble dryer motor turns weakly without the belt.
The brushes in the motor are probably shot. Good luck in finding those though, best to just replace the motor.
Dec 09, 2013 | Bosch Axxis WTA 3510 Electric Dryer
Looking for a replacement belt for a bosch axxis wta4400us dryer there don't seem to be links or parts lists readily available. Where can I find one?
The Belt you need for this machine, is the same one needed for a Danby DCD5505W Dryer. You can find a replacement belt at Repair Clinic, belt #669956, and you can also look-up a supplier using the mfg belt number (8PH 1930). The belt, with shipping is about $20.00
May 04, 2011 | Bosch WTA4400US WTA 4400 US Axxis Vented...
Where can I find a step-by-step procedure fo replacing a belt on our dryer?
The instructions on replacing the belt on your dryer may vary depending on your dryer. However the principle on most dryers will be the same. A good video that will give you an insight and use is on the link below:
http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Hope this helps
Dec 30, 2010 | Microwave Ovens
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Bosch dryer has pwr but not turning on
Sounds like the belt is broken or off of track.
Jun 03, 2009 | Bosch Nexxt 500 Plus Dryer
Best way to replace drum belt
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 18, 2009 | Bosch Axxis WTA 3003 Electric Dryer
Drive Belt on BOSCH WTA 3003 dryer
No,It`s quite a difficult & fiddly job.
Nov 10, 2008 | Bosch Axxis WTA 3003 Electric Dryer
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Dryers Logo
89 people viewed this question
Top Dryers Experts
