(972) 859-0929
Honest, Dependable, Available &...
If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS.
In some areas of the country, spiders or small
inserts have been known to create "flashback" problems. The spiders
spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury.
To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI
assembly should be removed from the grill and cleaned before use
whenever the BARBECUE has been idle for an extended period of time.
