Question about OKI C3200n Led Printer
Oki Printer c3200 error code
Hi
I've had an error code 543 - k toner sensor error...
what do I do to fix this...? is there a way to reset? I've taken the K toner cartridge out , cleaned, wiped off the sensor..this helped as I was able to print a few more pages, but now i have the error code again and unable to print...massive deadline and 200 color copies...not sure what else to do...
please help...:(
Mischa
  • 1 more comment
  • JoshuaJR Oct 01, 2008
    Mine is doing the same thing with the yellow toner :(
  • renelynn Oct 22, 2008
    i have same...mine indicates 541:M toner sensor error...cannot print.
  • mfowle Nov 03, 2008
    I am having the same issue. I have tried cleaning the little window with the white flap on
    the toner. I have ensured the sensor itself is clean. I have even
    gone so far as to completely change the toner and drum. Each time I
    will get short term use out of the printer, anywhere from a few hours
    to a few days, and then the sensor error will return. This morning, I
    have tried everything again but cannot seem to get the error to clear
    out. Does anyone have any other suggestions as to what might be
    causing this issue and possible solutions?
    Thank you very much
  • 4 Answers
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Posted on Oct 27, 2008
I have replaced the toner cartidge and it is displaying 543 sensor error on my OKI 550
take a look here :
http://www.c5200.co.uk/index.asp?menumode=0&content=sensorerror
Oct 13, 2009 | OKI C3200n Led Printer
543:K toner sensor error. How do I fix it?
Hi dianabusk:
You have a bad K (Black) toner cartridge or the sensor is dirty,the sensors are located on the toner cartridge and in the machine where the toner cartridge seats. Try cleaning the sensors and/or replace the K (black) toner cartridge. The sensors are a silver color.
Hope this helps
Sep 26, 2009 | OKI C5150n Led Printer
My Oki C3200 has the following error message 541:m Toner Sensor Error
There are several reasons for this message... we will start with the easiest to solve. Here is a link:
http://www.katun.com/downloads/oki-c5100tnrcartiis.pdf
Jun 03, 2009 | OKI C3200n Led Printer
Toner sensor problem k toner 543
Try reseating the toner cartridge, it might not be in good. Reseat the whole drum unit (the part the toner fits into).
May 03, 2009 | OKI C5150n Led Printer
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
543 K: Sensor Error
I had the same problem, after lots of work and fooling around..............Place a piece of white paper in the window where the sensor looks
Jun 18, 2008 | OKI C5200n Laser Printer
Toner sensor problems
sensor window on the drum is closed - or the r/h side of the printer has a sensor that needs cleaning.
Dec 24, 2007 | OKI C3100 Led Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
OKI C3200n Led Printer Logo
1,476 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
