Question about Dell Inspiron 1200 Notebook
Changing computers upload settings
I went to a sight that tested my computers uplading setting and it told me 150. Im trying to run a magic jack and talk on the phone on the computer. magic jack personel says that their upload is 250 and thats why the phone is staticy and isnt working well. she sd i needed to change my computers upload settings to 250 and it should work properly. can u tell me how to change these settings? ur co worker recommended u his name started w/p but am not sure exACTly how to spell it.ty
  • Dell Master
  • 13,433 Answers
Hey, I sent you a clarification reguest in which I requested you to run a speed test at www.speedtest.net and report me the results it gives you. seems it was removed.
Then we can move on and see what can be done about it.
Posted on Sep 02, 2008
Old majic jack want to start new program
If you have an old Magic Jack, my 4 unit are 6 years old the company just really wants you to upgrade to a newer product no need to. Try removing Magic Jack completely from your tablet, restart unit, make sure to clean out all junk on tablet from Magic Jack you could try a program that cleans your tablet for you, but unless you know what to remove don't get technical just a standard clean up of old files, this is usually under apps, Magic Jack, then there will be a clear cash button, clear data, and uninstall.
Restart unit then do a fresh install of Magic Jacks new app for your type of tablet from Googles sight or Magic Jacks make sure if you have a Mac to install the Mac App and if you have an android tablet you install the Android App. This has been working for me. With the old Magic Jack you will need to do a fresh install when you get errors and crashes. I do it 2 or 3 times a year. Good Luck!!
Jan 06, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
I have an Arcsoft webcam and it will not allow my video to come on when I'm on skype. The magic-i thing prevents it my video to work on skype. How do I get rid of Magic-i?
im not sure what this magic-i thing is if its a program you might uninstall it
click start all programs look for this magic-thing or you might go add remove programs to uninstall it click start control panel add or remove programs see if this magic-thing is there as a program
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
Jul 16, 2011 | Computers & Internet
I'm trying to get my Magic Jack to work with my HP 6210 all in one printer. The system test says everything is working fine, and the machine appears to operate correctly when faxing, but the faxes don't go...
Honestly, Magic Jack will only mess your computer up more then it's worth in savings.
If you really want to leave the phone company, check out OOMA (ooma.com) it cost more in the begining, but saves WAY more in the long run.
Of the 10 computers I tried to fix after Magic Jack had been installed on them, I had to reinstall the Operating System on all of them. Magic Jack is worthless.
Aug 16, 2010 | Computers & Internet
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
Calls cutting out with magic jack
Your ISP connection speed may be inadequate. Typically, the upload speed (outgoing voice) is much slower than the incoming speed. To check majicjack recommends that you test your system on http://www.speakeasy.net/speedtest/ .
It's also possible that your internet provider is purposely delaying the outgoing latency in order to discourage VoIP that THEY don't provide. I think this is (or at least should be illegal) but in any case a complaint to the FCC might be in order.
Aug 23, 2009 | Computers & Internet
I have magic jack and am trying to use it for a medical device because I have a pacemaker and defibulater and it need to be monertered by a LATITUDE COMMUNICATOR.Can magic jack be used for the LATITUDE...
I have and use Magic Jack too..Does your Latitude Communicator just plug right into a phone jack with a regular phone cord? If it does, then it should work...You will have to always leave your laptop on and never turn it off because Magic Jack requires a constant connection...Plug your equipment into the back of your Magic Jack and then with another phone, call the company that monitors your pacemaker/defibulator and ask them to "test" your line to see if you will receive a signal from them through your Magic Jack...You will to have to plug it all in and then test or you won't ever know...When I plug my home phone into the back of my Magic Jack, I receive a dial tone just like it was connected to a home based landline phone
Jul 16, 2009 | Acer Computers & Internet
HEADPHONE MIC
The headphones need to be plugged into the green jack on the computer, your microphone needs to be plugged into the pink(red) jack on the computer.
Mar 25, 2009 | Acer Power 1000 PC Desktop
Warning: YOu must Plug Magicjack into USB
This link fixed my PLUG magicjack IN USB problem: (tried all the other links mentioned in the forums and this is the only one that worked)
http://upgrades.magicjack.com/upgrade/upgrade.exe
Dec 13, 2008 | Computers & Internet
Need to know how to change the computers upload settings
The "whatevers", is that the speed, ie.. kbps, or is it the size of the program? Post this and I'll have a better idea of what's happening.
Aug 30, 2008 | Dell Inspiron 1200 Notebook
Dell Inspiron 1200 Notebook Logo
73 people viewed this question
Alun Cox
