Question about Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 52HMX95 DLP has weird gray think line
I have a toshiba 52HMX95 DLP HDTV that i bought about 2.5 years ago. Just recently I noticed that the tv has about a 1 inch think gray line that goes down the middle of the screen. Everything else works perfectly and this line is very hard to see when there is a dark picture, but when the picture is bright you can clearly see it. It almost looks like a shadow of some sort. We just finished moving and I didnt notice it until after we moved, so did something maybe happen during the transport of the tv? Any help you could provide would be greatly appreciated, thanks in advance.
  • badger5828 Sep 02, 2008
    Thanks so I'm assuming this is something I cannot fix and I need to contact the repair center?
  • Toshiba Master
  • 19,396 Answers
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Posted on Sep 02, 2008
  • Ginko
    Ginko Sep 02, 2008
    Yep, unless you did similar repair jobs before, for the integrity of your TV, it is better to call a technician, as you will need to take apart the TV to inspect the light tunnel.
I have no sound output what so ever. Not even in the ewxternal hook ups. Toshiba 52HMX95 tv
Disconnect the DVD and see whether it is working. Also see whether any jack is plugeed in the headphone socket.
Jun 29, 2014 | Toshiba 52HMX94 52" Rear Projection HDTV
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba 52hmx95 dlp tv. took back cover off. the fan cooling the lamp,makes a loud humming noise.read that fan is hard to get.(this is a three wire.only finding two wire.)is there a three wire fan i can...
maxie99,
Fan is available at https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6475656&smodel=52HM95 for about $80.00. Replacement should be as simple as unplugging the fan cord and removing a couple screws to remove. Do the work with the unit unplugged from the wall. Reverse the procedure to install the new unit.
Thanks for using FixYa and the great rating.
hardrocko
Oct 19, 2010 | Toshiba 52HM95 52" HDTV Projection...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
What are the blinking light codes on a toshiba dlp meAn?
90% of the time your lamp needs replacing.( DLP sets only )
Jun 18, 2009 | Toshiba Televison & Video
Constant Buzzing sound when TV is on
The wiring may have fallen back onto the fan or that may never have been the problem at all. A common problem for DLP TVs is the color wheel motor. It will hum and change pitch especially as you power the TV on or off. Its an expensive repair in this TV because Toshiba does not sell it independently from the larger, more expensive light engine assembly. Don't allow this to fall out of warranty! Call the extended warranty company and tell them that the repair was not effective and that you want this resolved promptly before the warranty expires.
michtech
Jan 25, 2009 | Toshiba 62HM95 62" HDTV
Toshiba LCD 37" with gray band and blue line
Unfortunately you are right it is the display panel going bad. You can either live with it or buy you a new tv as the panels usually cost as much or more than the tv. Sorry.
ladytech
Nov 01, 2008 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Open Questions:
Toshiba 52HMX94 52" Rear Projection HDTV Logo
367 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
