Question about Intel Motherboard
Atx pwr 8 pin connection
My motherboard has this connector my power supply dous not
    Brigadier General:
  • 5,158 Answers
Need to get another power supply for the board.
Robert
Posted on Sep 01, 2008
ATX motherboard connector pin out
Black=0V(GND)
Yellow=12V
Red=5V
Orange=3.3V
Purple=5Vsb(everytime on)
Gray is PWRGOOD or PWROK(pwr=power) must be at 5v
White=-5V(optional)
Blue=-12V
Green is PWRon must be connected to a black wire to turn on the PSU
Nov 16, 2012 | Enhance Technology ATX-1123B, Enhance...
New GA-990AX-UD3 motherboard will not boot
You really should take that Power Supply, and use it on grandma's computer.
The 8-pin EPS +12 Volt power cable was brought out, to provide more power To the motherboard AND processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
The 4-pin ATX +12 Volt power cable has TWO yellow wires.
Yellow wires are 12 Volt wires. (And two Black ground wires)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The 8-pin EPS +12 Volt power cable has FOUR 12 Volt wires.
In the motherboard manual, does it say, "Yes Tom. Go ahead and use a 4-pin ATX +12 Volt power cable. We don't care. We just use an 8-pin EPS for fun."
[ This is an 8-pin PCI Express power cable. Completely different,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8 ]
The motherboard probably uses 150 Watts by itself.
No Ram Memory, no CPU, no fans, etc.
The CPU could use up to 125 Watts of power. Just depends on what AMD, socket AM3, processor you are using.
Now to graphics card's power;
The most Wattage a PCI-Express x16 slot can deliver is 75 Watts.
The most power a 6-pin PCI Express power cable can deliver is 75 Watts.
8-pin EPS +12 Volt power cable? 150 Watts.
When buying a Power Supply you should calculate all components needing power,
http://extreme.outervision.com/psucalculatorlite.jsp
,then buy a Power Supply that has AT LEAST 10 percent more power than needed. Easier on the Power Supply.
Also a computer will NOT use more power than it needs.
10,000 Watt power supply, (Exaggeration ), and the computer only needs about 100 Watts for surfing the internet?
Computer ONLY uses 100 Watts.
Due to the price, the above, and the availability, you should use a 500 Watt power supply at least.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899123&CatId=1079
http://www.amazon.com/StarTech-6in-Pin-Power-Adapter/dp/B002O21XHQ
Or use it on yours if it has enough Wattage.
Back in the day, the motherboard didn't need to supply that much power to components on it.
More powerful Processors, Ram Memory, and graphics cards, brought the power needed, up.
A 4-pin ATX +12 Volt power cable was added for the motherboard. Then 6-pin PCI Express power cable for graphics cards. Then the 8-pin PCI Express power cable for graphics cards. Lastly the 8-pin EPS +12 Volt power cable.
(Better make sure the Power Supply you have is good, if you wish to use the above power adapter cable. Nothing like having a Power Supply with a weak voltage power rail, and a new build, to pull your hair out on )
http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
Out of the motherboard manual Page 23,
"With the use of the power connector, the power supply can supply enough stable power to all the components on the motherboard. Before connecting the power connector, first make sure the power supply is turned off and all devices are properly installed. The power connector possesses a foolproof design.
Connect the power supply cable to the power connector in the correct orientation. The 12V power connector mainly supplies power to the CPU. If the 12V power connector is not connected, the computer will not start.
To meet expansion requirements, it is recommended that a power supply that can withstand high power consumption be used (500W or greater). If a power supply is used that does not provide the required power, the result can lead to an unstable or unbootable system."
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 25, 2012 | Gigabyte Technology GA-990FXA-UD3-...
SuperMicro H8QG6-F Continous Beep
http://www.supermicro.com/Aplus/motherboard/Opteron6000/SR56x0/H8QG6-F.cfm
Under the Link and Resources heading, in the blue banner to the right, click on - Motherboard Manual
Page 32 of the PDF file. Page 2-10 for the manuals actual page,
2-7 Connector definitions:
Power Connectors
"A 24-pin main power supply connector (JWP1), and three 8-pin CPU PWR connectors (JWP2 / JWP3 /JWP4) on the motherboard.
These power connectors meet the SSI EPS 12V (Volt) specification.
In addition to the 24-pin ATX power connector, the 12V 8-pin CPU connectors at JWP2 / JWP3 / JWP4, MUST be connected to your power supply.
Warning: To prevent damage to the power supply or motherboard, please use a power supply that contains a 24-pin and three 8-pin
power connectors.
Be sure to connect these connectors to the 24-pin (JPW1) and the three 8-pin (JPW2,JPW3 and JPW4) power connectors on the motherboard.
Failure in doing so will void the manufacturer warranty on your power supply and motherboard."
So there you have it.
YES.
These,
NOT these,
Regards,
joecoolvette
Sep 02, 2012 | Super Micro Computer SUPERMICRO H8QG6-F
My motherboard takes this: 1 x 8-pin ATX 12V power connector My PSU (power supply) only has the 4-pin 12V power connector. Can someone please point me to a product that will convert the 4-pin to an...
Hi Andrew.
Just had a look arouund on Amazon, and if you do a search for
EPS 8-Pin Power to ATX 4-Pin Cable
There are a couple that turn up.
Hope this helps.
Apr 16, 2011 | Computers & Internet
I Just bought a Corsair Cx-500W P4 ATX power supply, but I can not connect it to my Asus P7P55D-E/LX P55 LGA1156 motherboard because of to many cables(confusing)
You need to connect the 20 or 24 pin connector to the ATX power slot on your motherboard, its the long rectangle one. You will also need to connect the CPU power to the CPU power slot, that is the 8 pin one. I hope this helps.
Feb 26, 2011 | Computers & Internet
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
Supermicro X6DAL-TG boot problem
I have 3 of these boards; however, they all have the Nocona Xeon with a Front Side Bus speed of 800MHz. The manual does not say anything about using a 533fsb. A second thought was if your power supply is an ATX with a 24 pin power connector and two +12 connectors one 8 pin and one 4 pin? The manual states all three need to be connected for the Xeon Processor.
Mar 30, 2009 | SuperMicro X6DAT-G Motherboard
I need a diagram of the atx pwr connector for an ASUS P4V8X-MX
If you mean power to the devices themselves, the 4-pin connectors coming from the power supply plug in to the drives. The red wire is +5 volts, the yellow wire is +12 volts and the black wires are ground (earthing) connections. IDE hard drives and CD drives use the same connector. SATA drives may have that same connector as well, but most use a different style. SATA-ready power supplies will have 1 or more plugs available. Adapters to switch from the 4-pin IDE plug to SATA type are available for supplies that don't have the right connector.
If you are asking what power pins from the mainboard power supply connector are supplying power to specific controller parts on the mainboard, that kind of detailed information is not available. Mainboards manufacturers do not supply circuit diagrams or repair information. They simply replace any boards that fail while still covered by the warranty, and expect you wil just buy a new one if the warranty has expired.
Much information about ATX boards including the power supply cable pins is found here:
http://en.wikipedia.org/wiki/ATX
Feb 09, 2009 | ASUS P4V8X-MX Motherboard
Need the area on the motherboard
The SW1 Connector
This panel connector provides a set of switch and LED connectors found on
ATX case. Refer to the table below for information.
Device Pins
HD_LED_P 1
FP PWR/SLP 2, 4
HD_LED_N 3
RST_SW_N 5, 8
RST_SW_P 6, 7
KEY 9, 10
Pins 1-9 are closest to the edge of the board. Pins 2-10 are above 1-9. Number 10 is missing .
Dec 10, 2008 | EliteGroup K7SOM Motherboard
Powering up
You need to remove the cap from 8-pin EATX12V connector and connect 8-pin EPC +12V power plug from your P/S, otherwise it will not work. Your power supply should support 8-pin EATX12V. If you P/S comes with 4-pin connector only you just use your 4-pin open spot and leave the cap on.
May 22, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Intel Motherboard Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
