Switching on the tele this morning, the normal blue background is now half red and half blue.....(top half red) so that while watching a program now people have green faces.......weird!!
  • 927 Answers
Good Day, deejay268;
Try resetting the entire system by unplugging the tele and the boxe. Unplug from power source for 3 to 5 minutes, then re- connect. Good Luck, big IRISH.
Posted on Sep 01, 2008
Samsung PS-63P71FH top half switching off
the buffer board in one side has problem.
Aug 15, 2012 | Samsung P63FP 63" Plasma TV
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sanyo tv when switch on has a blue box with
my sanyo tele isnt switching on, there is a white light flashing, but nothing is switching on?
Jan 02, 2010 | Sanyo Televison & Video
My set has a RED background on all Inputs--DVD,Sat, Recorded DVR.....when playing a DVD a Bright Blue FBI screen is normal and the Bright Green Movie Rating Screen is Normal but the picture is RED....
I found a way to get into the service set-up....press Display, 5 ,volume + and Power.....green numbers come up---could figure out how to go to a Menu-----but somehow the picture is now perfect !
Anybody know why this fixed it......as I said the RED background was on all input screens....the screen with no signal was a solid red instead of Black......
bob
Jun 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
In visual basic how will we change the backcolor of the form randomly when we click the command button?
Paste this code on you button. This generates a random color.
Red = Int(Rnd * 255)
Green = Int(Rnd * 255)
Blue = Int(Rnd * 255)
Form1.BackColor = RGB(Red, Green, Blue)
Oct 06, 2008 | Computers & Internet
TV took a dump
Sounds like a problem with the Hyper Board.
Dec 13, 2007 | Toshiba 65H81 65" Rear Projection...
When watching dvd having showing or fade background
yes it can be down to signal degradation especially via scart lead, make sure you use a decent scart if you buy an expensive one you can tell the difference. Run a cable from your sky digibox direct to your tv to see if the picture improves.
Oct 05, 2007 | LG 42PX4DR 42 in. Plasma TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
