Question about RCA R52WM24 52" HDTV Projection Television
Covergence is messed up
There are blue lines around all the people and words as well as at the top and bottom of screen. I tried autoconvergence and manual. Neither worked. I looked online and someone said that a fuse is blown and must be soldered. Who does this and how much do they charge? Thanks
  • Anonymous Sep 12, 2008
    • rca r52wh74yx58 convergence problem
  • vivalasherry Oct 25, 2008
    please help did anyone self fix this and if not how much did it cost to fix?
    i only have the tv a lil over 1 year so I am really upset
    Genius:
  • 1,030 Answers
If you have this problem. i have seen so many of these i wote an article under the tips and tricks sections. intitled the fl231 problem..
Posted on Oct 03, 2008
Color is out of balance on bottom half of screen
This tv have covergence problems,it dead.The convergence board the 2 STK covergence ICS and some or all it resistors are dead.Must replaced these parts to solved convergence problems.The shop will cost u $300-350 for parts and labors.
May 23, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Mitsubishi WS-55605 TV has covergence problems
advanced settings and click on convergence then you need to muve manualy there soud be a big cross to ajust wit your remote contro u have to muve it with the arrows up and down or right to left good luck
Nov 05, 2009 | Mitsubishi WS-55805 55" Rear Projection...
MY TV NOW SHOW BLUE AND YELLOW AT THE TOP AND
i have a 52 in rca tv and i turned it on and now there is a blue and yellow stripe at the top and bottom of the tv. and the people have a blue shaddow around them ? how can i fix this?????
Aug 25, 2009 | Hitachi Televison & Video
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
My mp3 Is Acting Rertarded!
the mp3 is done. and before you buy a new one try changing the screen resolution and brightness. and the next time you buy and mp3 get a warrenty on it, it only causts like 5 bucks, and if you already got one bring it to a store and the reciet and ask about it.
May 25, 2009 | Philips GoGear SA3125/37 MP3 Player
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
