Question about Kenwood KSC-W800 Car Speaker
Ksc-w800 installation Do I need a separate amp to use the ksc-w800 sub?
  • Tuckca Sep 01, 2008
  • 1,586 Answers
Any sub will need an external amp - a head unit amp doesn't have the suds to drive it. You can try it with the deck but you'll only get a whisper out of it.
Posted on Sep 02, 2008
How do you install w800 givi rear luggage rack
The Givi rack used on W800/540/400 comes with universal mounting brackets, connectors, fasteners, nuts & bolts.... and of course, some form of 'Manual' to guide you. But don't expect a step-by-step manual, since it is a universal rack system and therefore will have to suit different bikes' designs.
Depending on the installer's (you, your friend or your friendly mechanic) experience and also if he/she isn't rushing it, the end result could look okay or a bit messy. Personally, I don't like it... :)
Jun 29, 2014 | 2011 kawasaki W800
How do you hook up a sub and amp to a stock radio with NO RCA outputs?
you can splice into the wires for your rear speakers and install some of your owns rca's and just use the low pass filter on your amplifier to eliminate the mids and highs from the frequency to your subs.
Jun 24, 2009 | Kenwood KSC-WD250 Car Subwoofer
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
How do you wire sub speakers to change omes
if you have a 4ohm sub you can series it with another to make a 2ohm load. this is done by + from amp to + on one sub then take the - of that same sub and run it to the+ of the other sub then you only need to run a wire from - of that sub to the - on the amp. NOTE IF YOUR AMP IS BRIGED THIS IS A 1 OHM LOAD!! IF THE TOO SUBS ARE ON ONE CHANNEL THIS IS A Two OHM LOAD IF YOU ARE RUNNING 8 OHM SUBS THEN YOUR AT 4OHM PER CHANNEL AND 2 OHM BRIGED
Jun 13, 2009 | Kenwood KSC-WA82RC Car Subwoofer
I just got the Kenwood Sub KSC WA100 from my cousin with no electric wires or nothing so pretty much what all do i need and where can i find it i will be putting it in a 07 nissan sentra 2.0
Subs are subs, they come with no wiring. You need an amp and all necessary wiring to get it bumping. What type of deck do you have? Where will the sub be placed? In the trunk? Amp install is easy. Also suggest purchasing one of those amp kits for $20-$30, makes it a bit easier.
May 03, 2009 | Kenwood KSC-WA100 Car Subwoofer
Remote wire
If it is one sub with one amp, one remote needs to be hooked up. Not familar with your exact set up, but should stay constant for all. The remote signals the amp to turn on power when the deck is turned on thats it.
Aug 22, 2008 | Kenwood KSC-WA100 Car Subwoofer
No Sound from Subwoofer
You should be able to check this yourself pretty easily, Just connect the power and turn it on. Connect an audio cable to the input. Make sure the level control on the sub is turned about halfway up or more. Now, touch your finger to the tip of the plug on the other end of the audio cable. You should get a nice hum out of the subwoofer. If not, then the sub is bad - if it has a user-replaceable fuse you might check that first. If you do get a hum out of it, then the sub is ok, and the problem is elsewhere. Might be a simple as a bad cable or an option on your amp/receiver is set wrong.
Feb 14, 2008 | Kenwood KSC-WA100 Car Subwoofer
Kenwood KSC-WA82RC active sub
7e83231.jpgI had the same problem. Here is the picture i used.
Feb 04, 2008 | Kenwood KSC-WA82RC Car Subwoofer
Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Nov 27, 2007 | Kenwood KSC-WD250 Car Subwoofer
Installing
7e83231.jpgI had the same problem.  Here is the picture I used.
Oct 28, 2006 | Kenwood KSC-WA82RC Car Subwoofer
Car Audio & Video Logo
168 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
