Question about Refrigerators
Hotpoint ultima frost free ff200m warning trianle alarm noise and the temp range start flashing
SOURCE: I have a hotpoint fridge
I have tried the above solution without success. The only solution to the problem that works is to empty the fridge/freezer switch it off and allow it to do a full defrost. Then switch it on again. This appears to have sorted the problem
Posted on Jun 01, 2008
  • 139 Answers
SOURCE: my fridge freezer Hotpoint Mistral
E8- Evaporator thermistor short circuit
Well this is a sensor,, found in the freezer compartment of the f/f
what you have to do is reove the draws fro mthe freezer and you will c a panel which has 6 screws., remove the panel and and you will c a fan, toward the right of the fan you will c a yellow plug with a bit of wire on it,
This is what you have to replace
try connect distributions you can find them on the net if your in the uk that is
hope this helps
cheers
washdoctor
Posted on Aug 25, 2008
  • 10 Answers
SOURCE: hotpoint freezer fza54 frost free,
Power off the freezer.
Remove all freezer drawers.
Remove the four screws retaining the ducting at the back of the freezer compartment. Top at the top, two at the bottom
Carefully pull the ducting out - it's located in the guide slots for the freezer drawers, and should pull out without too much drama.
This exposes the air circulating fan, and the evaporator coil (the bit that gets chilled).
In my case, despite a defrost of the frost-free section, the evaporator section was one massive chunk of ice. If you have similar, carefully defrost this, and check the drain hole at the bottom of the cavity.
Re-assemble, as reverse of above.
Mine's been trouble-free since doing this.
Posted on Sep 19, 2008
SOURCE: whirlpool frost free tropical, seems
Check the sensor in the refridgerator... on the right,,
Posted on Sep 22, 2008
  • 122 Answers
SOURCE: hotpoint ultima ff200m manual needed
contact www.ff200m.co.uk/index.html
Posted on Apr 15, 2009
Hii m habing problem with hotpoint ff200m Fridge is workng gfin but freezer not working. I have removed the panel to check. the fan and fan is working. Im still getting warning triangle light on
The freezer is the important side- if the unit can maintain fridge temps, but not freezer temps- you have a sealed system leak and are losing the refrigerant volume needed to create sufficient cooling. When you remove the freezer panel, there should be a fine layer of white frost across the entire length of evaporator tubing... GE Compressor WR87X20798
Jun 19, 2016 | Hotpoint Refrigerators
My ultima ff200m isn't cold enough, what can i do?
Hello there and thank you for choosing fixya
Please check the following
Aug 04, 2011 | Hotpoint Refrigerators
Hotpoint ultima ff200m manual needed
Apr 15, 2009 | Refrigerators
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Servis fridge freezer
It may be that the temperature of the unit is not yet up to temp.The flashing light will indicate this.Warning the user the unit is not ready,or up to safe temp.. Let the unit run to catch up,since you just started it.
Nov 30, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Hotpoint FFL49X Fridge compartment
GE Hotpoint has a history of bad fans and poor customer service. Unfortunate and a costly defect. Repair this yearly, forever or trash and buy new???
Aug 14, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Hotpoint Range NOISE problem
I found the solution. The mercury light (according to my land lord) has crude and build up on it. This was located beneath the oven in the broiler. When it was cleaned the ringing stopped.
Apr 05, 2007 | Hotpoint RGB745 Gas Kitchen Range
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
