Question about Brother MFC 240C All-In-One InkJet Printer
HELP ON MFC-240C
I GOT THE ERROR MESSAGE WHEN I TRIED TO REPLACE THE OLD YELLOW INK WITH A NEW ONE ON MY MFC-240C ALL IN ONE BROTHER SYSTEM, THE MESSAGE SAYS:'NO CARTRIDGE, REINSTALL INK". WOULD TELL ME WHAT TO DO PLEASE? THANKS!
RAY
  • 679 Answers
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
NO CARTRIDGE message when new cartridge installed
Make sure there is ink in all cartridges and unplug the machine. Plug it back in while you hold the stop key and it should clear the error.
Nov 23, 2009 | Brother Multi-Function Center MFC-240C...
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Clean unable
Follow this LINK and rate me when you are done pls
May 02, 2008 | Brother Multi-Function Center MFC-240C...
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
178 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
