Question about Ovens
Bosch HBN13M551B Double Electric Oven
Hi I have this oven, and the bottom door is smashed, it has to be replaced. The hole dorr, i'm afrade. Where can i get a door for thi oven? Bosch HBN13M551B Double Electric Oven
  • Anonymous Mar 24, 2014
    Oven Displays " Please close Dorr" Letter "M" Blinking
  • 99 Answers
New door approx £150.00 you can get indevidual parts for it? regwoolley@uwclub.net
would need the enr no.!
Posted on Oct 11, 2008
Hi I have a Bosch Double Oven/convection Oven I
Don't know but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal.
Oct 04, 2013 | Ovens
Replace oven door seal
It will not be the door seal at fault. More likely is that the hinges are worn out or strained.
http://www.espares.co.uk/search/ma856pt1598/cookers-and-hobs/hinges/bosch
Try here.
Pete
Oct 03, 2013 | Bosch HBL 455 Stainless Steel Electric...
Bottom oven not working only fan & light works - top oven works fine
The ovens have separate heatin elements. Sounds like your bottom oven element needs replacing
Jun 30, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
Bosch double oven, the bottom door won't close all the way
This requires door hinges to be replaced,relatively simple job & parts cheap.Best buy parts from Bosch direct .
Mar 15, 2009 | Bosch HBL 5056 Electric Double Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Nov 21, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Oven door does'nt close fully
Heavy doors wear out the rollers on the hinge and the hinge itself. Need to replace them in a pair but the are expensive.
Apr 25, 2008 | Bosch HBL 5052 Electric Double Oven
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
199 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
