Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power ups for few seconds but powers down no picture just the green power button
What is ur opinion on this subject
  • RCA Master
  • 8,617 Answers
Most likely its the flyback as that model is famous for the flyback going out. It uses flyback number 259296 and you can get a replacement at the following link with free step by step instructions so you can replace it yourself.Heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 04, 2008
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
Blipping power
Ur tv power on the picture just show up only for a few sec. U still have sound?Yes,than ur LCD inverter board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 16, 2010 | ViewSonic N2000 20 in. LCD HDTV
Powers on but no picture or sound
i need a screen off a 47inch magnavox if u coudent fix urs and ur interested in selling me ur screen let me know
(47mf437b/37) noe28cervantes@yahoo.com
Jan 04, 2010 | Toymax Magnavox 47MF437B 47 in. LCD TV
TV shuts down after a few seconds no picture comes on
I have LCD AKAI TV , It shuted down and no picture . Power never changes from red to green when I press remote control or standby button.
Oct 03, 2009 | Sanyo DP50747 50 in. Plasma TV
Sony 42 inch wega when you hit the power button it goes to green for about 4 seconds then back to red and the tv picture never comes on or powers up.
Ur high voltage is dead.Ur FBT,call the Fly Back Transformer is dead.The block of plastic with a red wire with a cap go to the CRT(ur tv tube).
Sep 06, 2009 | Televison & Video
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Lense not closing, switching on for one second then shuts down. when attempting to turn on green light flashes then turns off
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Canon Cameras
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
