Question about Canon PowerShot S2 IS Digital Camera
E 18 problem
The lens on my Canon digital camera will not close... i am unable to take a pciture and do not know the reason for this....when the camera is put on i am able to see my old pictures but when i click to take a new picture the screen is blank..i dont know what to do...please help...i have the canon power shot sd 500 camera and the problem that appears is the E18...... please help me Same problem here. One night before shooting, the problem happened and I could not fix it. It had happened before, but a firm smack with the hand corrected the problem. No such luck this time on my S2 IS.
  • Anonymous Sep 03, 2008
    Same problem as described before. Lense stuck extended, when trying to switch on camera in picture taking mode, a motor can be heard that tries to move the lense, but after about 15 seconds gives up, and E18 is displayed on the screen.
  • 2,071 Answers
If your camera is still under warranty, the best thing you can dois to take it to the nearest official Canon repair shop and Canon Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Canon refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Olympus Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Olympus Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Sep 01, 2008
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
E 18 problem
Please follow the directions found here.
Jan 07, 2008 | Canon PowerShot A570 IS Digital Camera
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 12, 2009 | Canon PowerShot A400 Digital Camera
E 18 problem
Jan 08, 2009 | Cameras
E 18 problem
Try to use a diffrent memory card it will fix the problem
Aug 04, 2008 | Cameras
E 18 problem
I have the same issue "E18" on my powershot A95 and i don't know how i can solve it. Sorry. Loic
Jul 15, 2008 | Canon PowerShot A95 Digital Camera
E 18 problem
I just had the same problem. I sent the camera to the factory repair place and they fixed it in 5 days free. Even tho the camera is two years old and out of warranty.
Mar 01, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
