Question about Janome L-344 Mechanical Sewing Machine
Can't disengage machine to spin a bobbin with the needle moving
Do not have a manual for this machine so have no idea what to do. Anyone know?
Many times Janome will send a PDF of a manual free.
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Posted on Sep 01, 2008
After winding the bobbin on my Viking #1+ the machine acts as if I am still winding the bobbin and will not sew
I was unable t find a manual on the machine, but I would imagine you'd have to move the spindle inwards. That should disengage the spindle.
Dec 15, 2017 | Sewing Machines
I was given a 6510 still in the box. I have the bobbin in and threaded but the needle will not move.The bobbin winder is moved to the left.The motor runs but no movement. What can I try?
Did you disengage the bobbin winder? That is a safety feature to prevent the machine sewing at the same time as the bobbin is winding.
Nov 15, 2017 | Sewing Machines
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
Needle assembly doe not go up and down when the foot pedal is pressed but the bobbin does turn.
Make sure you have not disengaged the needle bar, such as when winding a bobbin. The manual says that when a bobbin is set for winding and the bobbin winder shaft is moved to the right, the needlebar is disengaged. If that appears to be okay on your machine, perhaps something in that mechanism is broken or misaligned preventing the needlebar from operating.
http://www.manualslib.com/manual/219390/Brother-Xl-2600.html?page=19#manual
Dec 31, 2015 | Brother XL2600 Mechanical Sewing Machine
Needle moving while trying to load bobbin and it wont spin
I assume you are trying to wind the bobbin. Sounds like the lever is not disengaging the needle head. If you \'ve had the machine a while, you may have the part under the bobbin winding area clogged up with thread lint and gunk. Get a penlight and try to see in the slit that the bobbin holder pokes through. You may need to take the cover off. If you do, then unplug the machine, remove the cover, and move the bobbin winder on and off and watch the other levers attached to it.
Aug 01, 2014 | Brother XL-2600
Wind bobbin frister rossman 420
Hi - if I understand your questions you're trying to wind a bobbin on the top, and haven't got as far as sewing yet.
To do this you usually have to put the bobbin on the top spool for it, and move that into position so that it turns.
To disengage the needle so it doesn't go up and down whilst you wind the bobbin up, on most machines you have part of the main drive wheel (on the far right) which turns against the rest of it, disengaging the part of the drive which powers the needle going up and down.
Or at least that's how it works on most machines.
Jan 28, 2013 | Sewing Machines
My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
I hope this helps!
Mar 29, 2011 | Singer 1120 Mechanical Sewing Machine
I have a kenmore sewing machine model #385.1249180. I cannot disengage the clutch knob from the hand wheel when I spin my bobbins, therefore the needle moves up and down as the bobbins spins thread. Do You...
Usually when you pull the clutch knob out it disengages the sewing machine needle shaft. At least, that is how my 2 Kenmore's work. You can always take your machine into Sears sewing department and ask the sewing machine salespeople for help, they are really helpful in my area and more than happy to help you for free. Good luck
Dec 23, 2010 | Sewing Machines
Threading the bobbin, disengage the needle
Depending what brand and model of sewing machine it is, you can usually disengage the needle bar with the knob inside the handwheel by turning it towards you. If you've done that and the needle bar still moves, it needs oil and should be serviced by a technician.
Feb 24, 2010 | Sewing Machines
Bobbin clutch just spins
Clutch is disengaged only for winding thread onto the bobbin.
When done, re-engage (tighten) clutch and with bobbin in bobbin case, hold needle thread, rotate handwheel until needle is top centre of it's motion then pull threads thru allowing approx 100mm (4") slack .....you are ready to sew.
If this isn't what you were asking, then I'm not sure why you have disengaged the clutch, so more detail please.
Feb 14, 2008 | Sewing Machines
Janome L-344 Mechanical Sewing Machine Logo
121 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
