Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
BLANK PAPER IS COMMING OUT
I TRY PRINTING STUFF AND ALLIM GETTING IS BLANK PEICES OF PAPER,
  • 21 Answers
Most likely your print head is clogged, there are 2,000 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try reseating the ink cartridges(take them out turn off power, unplug printer, power back on & wait for it to get done making noise) then proceed doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or www.kodak.com/go/downloads
Posted on Sep 03, 2008
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
Printer
Try printing the hardware test page, if it fails to print then it can be issue with the cartridges( may be using refilled cartridges) try cleaning the strip with soft cloth and head of the cartridge with damp cloth.
Sep 24, 2009 | Office Equipment & Supplies
I am printing blank pages, I have no errors and plenty of ink.
Try this clean the head of the printer, through the menus on the servicing the printer. If that doesn't work take a compress air can, and becareful of not get the liquid stuff into the printer, by holding it straight blow it into the printer. It could be as simple as paper dust or dust on the head itself.
Aug 11, 2009 | Epson Stylus Photo R200 InkJet Printer
HPlaserjet P1006 Series When printing getting a white blank streak down the middle of the page
To isolate the problem you need to do a 'half test'. This involves printing and stopping paper half way through the printer. This can be done by opening the toner door at the appropriate time. The paper should have just entered the fuser (watch out, the fuser is HOT). You should see the paper with the printing on it after removing the toner cartridge. Carefully turn the toner cartridge over and move back the door that covers the drum. DO NOT TOUCH THE DRUM. If there is the corresponding blank spot in the center of the drum, like the paper, the scanner is dirty or blocked. A can of compressed air will help here. If you have access to a different toner cartridge, you may want to try that first.
Jul 20, 2009 | HP LASERJET P1006 Printer
IMAGERUNNER C3200N PRINTED DOCUMENTS LOOKS YELLOWISH
ok if you are getting peices of rubber on the pabe it could be the fuser rollers.. this unit comes out easy.. looking at the unit there are 2 screws on both ends looking back at you... remove the screws and the unit lifts strait up once its out you can see the rollers much better. it is either comming apart or the teflon could be sliding off. if it looks ok you may need to run the paper thru slower it may not be fusing good 2 ways to do it try the bypass and select heavy 1 or you can set the cassette for heavy under add func common settings paper settings...
Dec 30, 2008 | Canon CLC 1180 Copier
Lexmark Z715 will not print but computer says it is printing
The Z715 needs a #50 black ink cartridge and a working color cartridge to print. To check if there ios ink coming out of your black or color cartridge touch the bottom of it to a paper towel and if you see a solid black blob or 3 blobs of Yellow, blue and red for the color then your problem is else where. If U are printing stuff from the internet sometimes the printer will try to use the color cartridge to print this so even though the black is working it comes out blank if the color is dry
Jan 16, 2018 | Lexmark X4650 InkJet Printer
HP photosmart 7280 - when printing with Toshiba or HP notebooks (both Vista) a blank page is ejected between EACH printed page of a document. HP had no solution.
Assuming that you are connecting directly to the printer via USB, on the advanced tab under the printer properties, make sure the "Print Directly to the Printer" option is selected.
Aug 16, 2008 | Televison & Video
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
Black line
Is the paper you are using a bond paper and a little heavy. The line is most likely comming from the fusing ass'y. Are you running it LTR size? Try runing it LTR-R size. It will not put as much fores on the fuser and it will run a little slower. Also try the by-pass. Or try to run some Blank White pages though it to clean the fusing ass'y. You also may need to rebiuld or replace the fusing ass'y.
Jan 22, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
51 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
