Question about Toshiba Computers & Internet
I am having trouble connecting my Toshiba laptop to my LCD Flat screen, I can only get the picture of the desktop to show on the tv, but none of the icon show up. I want to be able to get on the internet and have it show up on the tv screen.....I need help????
  • 2,961 Answers
You will need to change the screen resolution in the external monitor settings, as you must have them set at 800x600 or similair and it will need to be atleast 1280x800, just right click on empty space on desktop and select graphic properties
Posted on Sep 01, 2008
My toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Aug 03, 2012 | Toshiba 40E210U 40 in. LCD TV
No picture, only sound on LG 47LV5500: how do I get picture back?
Definitely odd for sound to come through and not sound, especially via an HDMI connection.
I would contact LG for support, your TV could be defective.
Good luck
May 28, 2012 | LG 47 47LV5500 47 LCD TV
I have my laptop plugged into my 32" Dynex TV and the only thing that is showing up on the TV is my desktop picture and the resolution preferences window when i open it. Is there a way that i can fix this?
sounds like your set up on extended screen where your laptop still show desktop and your tv shows only the desktop picture. if you have a fn button or like, should be next to the left ctrl button press it and on my laptop its f4 but maybe different on yours should scroll through the different output modes. failing that check your output modes on your laptop going to control panel/display properties and change your settings. hope this helps i can't tell you how to change them or what to change them to as i got a intel setup program for doing it.
Oct 23, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Jul 31, 2010 | Toshiba 32AV502R LCD TV
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged.
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
I want to connect my Toshiba Satellite A305-S6863 Laptop to TV
You have to configure yout laptop to output through the s-video (which does not carry sound, so you need to either use the laptop speakers for sound, or the line output (headphone jack) to the TV).
I don't know if all toshibas are the same, but with mine, if I hold Fn (near the windows key) and press F5, it will change the output, do it a few times until you see a picture on the TV, some settings make this your extended desktop, meaning you can drag a window from one screen to another.
Apr 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Connect LG 42LY95 LCD to Toshiba Laptop
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Mar 22, 2008 | Televison & Video
Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
Mar 18, 2007 | Toshiba 15VL33B 15 in. LCD Television
Computers & Internet Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
