Kta pro v1.0 bios problem
Have found kta-f1s.bin and ktaprob2.bin bios files but they are too old.
Have athlon 1700+ XP and still shows athlon 1400 in bios.
I know that this is real frequency of cpu but i want to se on startup ATHLON 1700+ XP.
Need lucky star kta pro v1.0 bios (more recent then above).
For support athlon xp models (the motherboard supports cpu to ATHLON 2000+ XP).
Thanks
davido_car@yahoo.com
  • Roberta Smith
    Roberta Smith May 11, 2010
    I won't guess... what is the motherboard number
    Robert
    Genius:
  • 1,027 Answers
You are right - a new BIOS upgrade should give the proper displays. Go to the motherboard's manufacturer's website to download the latest bios.
Posted on Sep 01, 2008
Amd athlon xp 2400+ problems witha epox ep-8kra2+ motherboard?
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
Feb 14, 2010 | EPoX EP-8KRA2+ Motherboard
PC shuts down after logging in to WinXP pro Athlon uP
reinstall the window xp
open my computer from the start manue
go to view and open folder options
show the hidden files and also deselect the protecting window files below it
and apply
then click on the folder on the top in the my computer
and remove all the suspected hidden files from all the drives and restart your system
Dec 21, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
When I switch on my Athlon XP 1700 Evesham computer the time and date is 23 06 2001
You need to press the setup keys indicated in your manual as the computer starts, go into the first bios page and set the time.
Sep 15, 2008 | Evesham Computers & Internet
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
CPU model not recognized correctly
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
Feb 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Compaq armada 1700 only starts on safe mode
If this is your notebook - Compaq Armada 1700 (316320-056) PC Notebook. The system memory only came with 32MB's of memory. Your not telling me enough. Have you recently upgraded your operating system? If I have this wrong please post which Compaq you have from the list I'm providing from this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=96221&taskId=135
If you are trying to run a XP version your memory will need to be increased to at least 512MB. You still have the Compaq's splash screen loading when you turn on your notebook which blocks you from seeing the amount of memory installed in your notebook. So when you start your notebook press the F12 key on your keyboard. You need to enter the bios. If F12 does not get you there than try F10 or F1 key. At startup. Repeat hitting the key every two seconds till the Bios screen loads. Look for the amount of memory installed. At the bottom of the bios screen is instructions on how to navagate while in the bios. You'll need to post back with what you found If I'm to help further.
Feb 07, 2008 | Compaq Armada 1700 Notebook
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
Computers & Internet Logo
522 people viewed this question
David Payne
David Payne
