Master
- Posted on Aug 02, 2011
Re: Hi, I am having a problem with my rf adapter for my...
- Well, if it broke off right flush with the pack then you would have to split the pack and re-soldier the wires on. This can be a big pain. No easy way but to carefully split it open. The original adapters sort of split in half.
- There is a little flex part on the end of the wire before the actual adapter. If it broke off there then you can carefully splice off the little end piece lengthwise making sure not to cut the wire itself.
- When that is removed then you can splice the two wires together. I recommend soldiering them together and insulating with shrink tube. Electric tape will work temporarily (see photo)
- Hope this helps and thank you for using FixYa.
Regards,
Tony
