On repitition take input from the user .for eg: 2now print how many times 2 is present currently for eg:1 times 2 will be printed as : 1 2 now 1 appears 1 times .so next out put will be : 1 1 1 2 (2 appears 1 times) similarly 3 1 1 2 1 3 2 1 1 2 like this we have to print 10 lines
    Sergeant:
  • 336 Answers
What is your question
RCF
Posted on Sep 02, 2008
Sample of how to create a python program that will input two numbers and will ask the user of operation to perform as to addition,subtraction,multiplication or division the program should perform the...
Assuming that the input numbers are given by the user:print "Menu"print "1. Addition"print "2. Subtraction"print "3. Multiplication"print "4. Division"print "0. Quit"
a = input("Please make a selection:")if a == 1: x = input("Please enter a number:") y = input("Please enter another number:") answer = x + yprint "%r plus %r = %r" % (x,y,answer)elif a == 2: x = input("Please enter a number:") y = input("Please enter another number:") answer = x - yprint "%r minus %r = %r" % (x,y,answer)
The same goes for everything else just with different signs. Don't forget that "*" is multiplication and "/" is division. Also, for 0. Just use:
elif a == 0: quit
Sep 28, 2011 | Computers & Internet
I have a HPC7280 all in one. it is asking to insert a memory card for copies. why? how do i get around that.
It sounds to me like you have selected an option to print directly from a memory card at one time. Here are excerpts from the user manual for your machine to change printer settings:
Change the print settings
You can customize the print settings of the HP All-in-One to handle nearly any print
task.
Windows users
Before you change print settings, you should decide if you want to change the settings
for the current print job only, or if you want to make the settings the defaults for all
future print jobs. How you display print settings depends on whether or not you want
to apply the change to all future print jobs or just to the current print job.
To change the print settings for all future jobs
1. In the HP Director, click Settings, point to Print Settings, and then click Printer
Settings.
2. Make changes to the print settings, and click OK.
To change the print settings for the current job
1. On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Make changes to the print settings, and click OK.
5. Click Print or OK in the Print dialog box to print the job.
I believe that this should help you get around your issue. Here is a link to the entire user manual for future reference.
http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf
Dec 22, 2010 | HP PSC 1610 All-In-One InkJet Printer
Help!!!! I wanted to print 1 page from a camera user manual and printer started printing ...200pages. How do I stop this thing from using all the ink and paper?
After opening the page to print, from the print menu select "Current page" or words to that effect. Presently, the default is "All pages".
May 22, 2010 | HP Deskjet D4160 InkJet Photo Printer
How can I make my printer print only in black also print what I want on a page
Printing in black is no problem.
Depending on what Operating System you are using - you will need to select print in gray scale in the printing preferences menu.
Normally the printer will only print what is on the page as seen in the output of the application. You can select the pages you want to print by selecting either current page or page numbers, eg, 1-5 or 1, 2, 4 etc.
If you want to print only what you want on a page then you will need to cut and paste the bits into a new MS word document (provided the output of the application allows cut and paste). You can do this with MSWord pages and IE and PDF pages to an extent.
May 08, 2010 | HP Office Equipment & Supplies
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Changing date & time on the QT-6000
1. Press [Mode]
2. Press [PGM1]
3. Input current time (in 24hours format, eg 9:30pm = 2130)
4. Press [X/Date time]
Aug 22, 2009 | Casio QT 6000 Point of Sale Terminal
Copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
Aug 14, 2009 | Kyocera Office Equipment & Supplies
Change Tax+ rate from current 8.25% to new, required 9.25%
http://www.casio.com/support/content/AF64A1AC-193D-4650-A9A9-98BB6FE26CFE#0
How do I program tax rate into my calculator?
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Apr 01, 2009 | Casio MS-80TV Scientific Calculator
Won't print current page on screen of my Macbook
Johnvestey,
Good day!
Printing documents is made easier for the user to have manuals. Your printer have actually manuals. But you can also get manuals from the web. just type the model of your printer i n the web site navigation bar so that you will have fast and easy research.
Down load the manual for your PC. It is necessary to listen
to commands before installation.
jonags,
Please rate so that I cam reply you a soom as i arrive..
Dec 28, 2008 | Canon PIXMA iP90 InkJet Printer
HP LaserJet P2015dn
sounds like you're dealing with Postscript issues here. Does your HP have postscript drivers installed.
you might want to check on the current Mac drivers through this link
Mar 08, 2008 | HP LaserJet P2015dn Printer
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
