Question about Toyotomi TAD-30F Portable Air Conditioner
Toyotomi td-2400 the tank is to be emptied when full - not filled - moisture is removed from the air and stored in that tank - to be emptied when full and unit will shut down when it is full.
2 Suggested Answers
SOURCE: The "tank full" light flashing
Dear-heart, the tank should be EMPTY...when it's full the machine shuts off to keep from over flowing.
Dump the water out and try again. The "flashing light" is to tell you the tank is full of condensate water and needs to be emptied.
In hot, humid climes this will happen often. Many models can be hosed for continuous operation.
Good luck
Anakron
Posted on Jun 23, 2009
It is not the anti thief systm
Could be as simple as an air lock in your fuel lines. Its best to never let your tank get below one quarter full as it can cause moisture to build up in your tank as well. It does not cost any more to keep a full tank than to let it run empty then fill it.
Oct 14, 2016 | Cars & Trucks
Has spark but will not start
Then gas must not be reaching the cylinder. Pump the pressurization bulb if it has one until it is hard. Make sure fuel cap is tight. Take out the spark plug and drip some gas into the cylinder. I use the old straw trick - stick one end into gas, plug the other with you thumb, move to saw and remove thumb. Immediately reinstall plug and wire and start it with choke off. If it starts and will not stay running, try one more time with choke on. If it won't run, the carb is probably bad, especially if it has sat a long time. Time for a shop visit. BTW, if stored long time with half full tank, condensate forms inside the tank during temp changes and new moisture enters when fronts change the air pressure. The water will be in the bottom of the tank where the pick up is. Empty the tank and refill with fresh fuel. Always store with the tank full.
Mar 09, 2015 | Garden
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
May 31, 2014 | Miele Coffee System
My Toyotomi TAD-30F 'tank full' light keeps coming on despite my emptying the tank daily.
Check and see if the light is activated by a float switch. If it is it may be sticking. Your owners manual may have a clue.
Jul 11, 2012 | Toyotomi TAD-30F Portable Air Conditioner
Ingersall-Rand T 30 Model 2340 Motor overload trips when trying to fill air tank. How long should it take to fill the tank with air with tank empty. If tank is full it may cycle one time when using air.
You need to know the size of the tank before you can figure pump up time from empty to full. It sounds like you have a bad tank check valve. A bad check valve typically causes the motor overload to trip when starting.
May 21, 2010 | Ingersoll Rand 2340/2475 Electric Air...
Twin tank Thomas Air-Pac 1.5 HP compressor but only one tank fill
THE GAUGE ON THE REGULATOR ONLY READS WHAT THE PRESSURE IS REGULATED TO NOT WHAT IS IN THE TANK. ITS VERY LIKELY YOUR REGULATOR IS BAD OR TURNED DOWN ALL THE WAY. YOU COULD EVEN HAVE YOUR QUICK CONNECT CLOGGED ON THE END OF THE AIR HOSE. MY MONEY IS ON THE REGULATOR THOUGH. TRY ADJUSTING THE REG. UP ALL THE WAY. IF THAT DOESNT WORK THEN DRAIN YOUR TANK TO ZERO, REMOVE THE REG. AND THEN TRY IT. REG. HAVE FLOW DIRECTION SO PAY ATTENTION TO THE ARROW WHEN INSTALLING. HOPE THIS HELPS, JODY
Apr 11, 2009 | Air Tools & Compressors
Smells like gas
anytime you smell gas turn off the gas at source quickly.
Dec 22, 2008 | Toyotomi TID-1800HP Air Conditioner
Unable to pump gas
This problem is caused by the fuel tank vent pipe being restricted, usually it is kinked, replace the filler pipe vent.
Nov 26, 2008 | 2006 Hyundai Sonata
You can find a user manual at http://www.toyotomiusa.com/products/manuals/TID-2400%20(Type%20A,%20B)%20-%2020456095%20-%20Multi%20Lingual.pdf
Jun 08, 2008 | Toyotomi TID-2400 Air Conditioner
Toyotomi TAD-30F Portable Air Conditioner Logo
108 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
