Question about Dryers
Kenmore dryer stock no. 69812 electric
Model no. 110.69812990
no heat
changed the element (3403585), thermo cut off (3399848), 250 thermostat (3399693), and thermal fuse (3392519).
  • skacoreny25 Jan 02, 2009
    dryer runs but no heat kemmore11096060100
  • 3 Answers
Many times it is not a problem with the dryer itself. Just as in automotive and housing, when no one thing can be pinned down, look for the simplest and least expensive fix first. This would include a look at the wall plug and the power cable.. Ensure the power is off first, then unplug the unit from the wall. Check first the 220 power recepticle, then inspect the cable and all connections for signs of blackening or burnouts. Repair/replace all blackened or burned wires and cables as needed. Often times, even a dirty connection will not allow electricity to flow.
Posted on Dec 24, 2010
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Heating problem with kenmore elite he4 electric dryer. drum turns, lent trap clean, heating element ohms ok, thermo coupler ohms ok, thermostat ohms ok, timer counting down. still no heat.
limit switch stuck open should be behind motor housing is a tight fit to get to but there are two there on the element one on vent tube the other is thermal switch recommend chang the two on the tube ck element limits should all read continuityif not reolace
Jan 26, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer will not heat. Think the heating element is bad. Where is it located on the dryer?
it is located at the back of the drum inside an oval housing. if the element coil is not broken, you may need the thermal cut off kit which is part #3977393, it contains 2 thermostats. the element part #is 3403585. hope this helps.
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Dryer won't dry - no heat
Make sure you have 240 volts going in. If you do, then it can only be the heating element or the thermo cut off located on the heater housing. Also could be the thermostat on the housing as well. The heater relay is possible, but check that last, it's most likely the element.
Mar 15, 2009 | Kenmore 62602 Electric Dryer
Dryer does not heat
Check the thermal cut-off, the thermostat, and the heating element. Most times one of the tree is the culprit.
I have seen a bad timer cause the no heat problem a few times but 99% of the time it is one of the three I mentioned.
If you change the thermal cut-off make sure you get both the cut-off and the thermostat. A stuck T-stat will take out a cut-off in a big hurry.
Feb 12, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
374 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
