Question about Frigidaire FRS26R4A Side by Side Refrigerator
Refrigerator My refrigerator stopped cooling the middle of the night. Side by side. Everything in freezer melted. Cleaned condenser. Fan is working. Compressor is running. Air is blowing into both compartments. I have the temp control turned up. Drain pan is dry. Could it be relay switch?
    Genius:
  • 2,920 Answers
Yes on top of the compressor
Posted on Sep 01, 2008
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
I have a whirlpool conquest side by side and it stopped cooling on both sides last night. I cleaned the coils and blew it out good and plugged it back in and the fan is working and the compressor appears...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
GE Eterna ESS25LGNA freezer side not working
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge model GSS201ETA NOT COOLING AT ALL
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
dsfhfs
Jun 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have hss25gfp side by side the freezer stopped freezing and it very hot on the middle divider. I took off the bottom on the back and it was caked with a bunch of lint. I cleaned it off. But noticed the...
If the compressor is running the condenser fan should be too. If the fan does not run the compressor will overheat and stop. If you cool the underside with a small box fan and the chill returns to the box, replace the condenser fan.
May 29, 2009 | Hotpoint HSS25GFP Side by Side...
My GE side by side refrigerator quit working.
The automatic defrost system is not working. All frost-free machines have a heater in the freezer to melt the frost away on a timed schedule. Every day or two the defrost cycle is initiated by the defrost timer. A heater melts the frost, then the cooling system is turned back on.
Mar 06, 2017 | Refrigerators
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer not freezing
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
109 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
