Question about Dell Axim X5 Pocket PC
Pda newbie - memory question
What is the difference between the two types of memory being offered on the Axim? Is one better than the other? Or do you need both?
    Master:
  • 852 Answers
If you are referring to the difference between Compact Flash and Secure Digital memory, then there is no difference, except the format. By providing two different memory slots, you are able to install more memory, or use one slot for memory, while using the second slot for other peripherals, like network cards, modems, or wireless cards.
Posted on Sep 13, 2005
SOURCE:
Dell axim x51v pda
You need to do a hardreset on the pda to get the password removed.
Jul 24, 2008 | Dell GG057 for Axim X51, X51v
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
Dell Axim PDA backup battery
There is a small wafer type battery inside the case. Similar to a CMOS battery in a PC. You need to replace it. You can do it yourself if you have the right tools, i.e. tork drivers. Battery is around $4.00 .
Dec 12, 2008 | Dell Axim X5 Pocket PC
Dell Axim x51v
You can get a replacement rechargeable one at batterytrader, here is the link - Dell Axim X51 battery, they also do a couple of extended versions just search on the site, this also fits the dell axim x50 pda batteries
Sep 18, 2008 | Dell Axim X50 Pocket PC
Good Eevening :
You could get original disk from ebay at times but all you need is the Activesync that can be downloaded from Microsoft. Get Active sync 4.2. The newer ones do NOT work with the X5.
Good luck with the wireless card. The Axim does not play well with many of them. (sometimes works but mostly not) Try drivers from d Link and be sure to remove the old drivers first.
Dec 02, 2007 | Dell Axim X5 Pocket PC
Email forwarding
You can only sync your inbox through Activesync with Outlook not Outlook express. There is a full version of Outlook on the CD that came with the Axim. You should be able to move your data from OE into Outlook.
Sep 19, 2005 | Dell Axim X3 Pocket PC
Connecting Axim plus Palm on the Same PC
I may be wrong but each PDA (assuming you are connecting different brands) have different drivers. I connected a Toshiba and Dell PDA and each required their respective install disk with their respective drivers. Then I configured each pda using the Active Sync Connection Wizard. Everything ran smoothly after that.
Sep 14, 2005 | Dell Axim X3 Pocket PC
AXIM X5
To copy word documents, simply connect your device to your computer, click "Explorer" in ActiveSync, and then transfer the word document from your desktop to your Pocket PC. ActiveSync will do the conversion from Word to Pocket Word for you. As for wireless internet service, you need a wireless Compact Flash card and data service. Sprint is one of the few companies that offers this, and there is also the Pocket Spider from Enfora which can connect on some wireless networks.
Sep 14, 2005 | Dell Axim X5 Pocket PC
PDA screen?
Reflective LCDs do not have a backlight, because of this they can be difficult to use in some lighting situations. The Transflective LCD can be read while unlit, by ambient light, but it also has a backlight, which makes it better in low light situations.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
43 people viewed this question
Clive
Clive
Alun Cox
