Question about Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DCC We recently had a storm which caused us many electrical problems at our home. We have fixed all issues and replaced many electronic devices. The last I need to either fix or replace is our microwave. The timer light flashes and the interior light comes on when I open the door, but nothing happens when I touch the keypad. Do you think I just need to replace keypad or do you think its something else? Thanks
  • Frigidaire Master
  • 9,086 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it doesn't would suspect you have a problem with your control board.
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 02, 2008
Frigidaire microwave fmv156dcc the timer goes thru the timing motion but does not cook.
Many of the newer microwaves are fused in the cooking portion of the unit. There is usually
A ceramic automotive style fuse in a holder inside the case of the microwave. Be sure
to unplug unit before attempting to replace this item (about 2 dollars at an appliance
parts store or even radio shack). The volts and amps are stamped on each end, normally
250V (250 volts) and 5A (5 amps) Be aware that the capacitors can hold quite a
residual charge similar to an electric fence, so be mindful of them.
(can shaped items with leads coming to them usually metal). Hope this helps.
Apr 26, 2011 | Frigidaire Microwave Ovens
Fmv156dcc begins to spark when powered on
Read my tip at http://www.fixya.com/support/r4265491-replace_bad_magnetron and it will explain your problem, what the remedy is and where to get the parts. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 12, 2010 | Frigidaire FMV156DC Microwave Oven
How to replace handle model #FMV156DCC
Pry the plastic trim which surrounds the glass window which will expose the screws...
Jan 27, 2010 | Frigidaire Microwave Ovens
Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
Aug 18, 2009 | Frigidaire FMV156DC Microwave Oven
Changed one of the door switches on my microwave now no power
check the green ground ground cable on the control panel
Aug 05, 2009 | Frigidaire FMV156DC Microwave Oven
How do I replace the door on a Frigidaire microwave, model FMV156DCC?
TIP: Go to the web and type partselect.com enter your model number then scroll down to your part. Click to enlarge exploded diagram on left and you will be able to view at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 13, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
1,227 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
