Question about Insignia Digital-to-Analog Converter for Analog TVs
Set - up
Which cable is the right or left? The white or the red?
  • 30 Answers
Red cable is usually used for Right audio channel, while the white cable is used for the Left audio channel. And the yellow cable is used for the video.
Posted on Jun 16, 2009
In my JVC RX 8SD only works a channel. How do I repair this defect?
Start with the simple things.
  • Check left right balance
  • Swap output speakers left to right
  • Swap the speakers at the receiver to make sure no wire open/short
  • Swap input RCA cables left to right red/white - white/red
Ok No JOY!
JVC has thermal overload circuits/overload on most of there Amps.
Remove power for a minute or two to see if there is a reset.
Rewire speaker connections to speaker set 2.
Connect REC out to Rec In swap cables and see if problem is in pre-amp or power amp.
Check internal fuses.
Jan 19, 2016 | JVC Audio Players & Recorders
Pyle troubleshooting
The projector has built in speakers.
Aug 06, 2014 | Pyle Home PRJHD66 1080i Front Projector
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
Wii is not in color on new samsung led tv
in the component area o
n back of tv connect wii's cables to the bottom row. yellow = bottom right with yellow circle and red and white to then going to the left and skipping 2 holes plug red and white into audio left and right . then set source on tv to AV
Dec 23, 2010 | Nintendo Wii Console
Using the red whit and yellow VCR cables, how do i
You must have a monaural (mono) TV even though it looks like you have speakers on each side. The VCR has stereo audio output red=right white=left yellow=video. Ideally you would buy a mixing tee to add the left and right signal. Or if your VCR supports it you can set it to mono output. Otherwise, just use the white (left) cable to feed the mono input (white) and of course the yellow to yellow for video. Just ignore the red wire or lightly tape over it to avoid any short. Best,
-Ken
Apr 16, 2010 | Apex Digital AT2402 24" TV
I have a dvd player drc212 that i have no
Hi Tana,
If your TV is supplied with a video input, you will need a set of Composite Baseband video cables commonly known as RCA cables (Yellow, Red, White).
See the last paragraph if your TV is not supplied with a video input.
You will connect the Yellow (Video) from the DVD's video output, to the Yellow (Video) input on the TV set; example is VIDEO 1 or AV1.
You will connect the Red (Right Audio) from the DVD's Red Audio output, to the Red (Right Audio) input on the TV set using the same input number as example above.
You will connect the White (Left Audio) from the DVD's White Audio output, to the White (Left Audio) input on the TV set using the same input number as example above.
Turn on DVD, and TV set. Select the proper input on the TV set using the input button (video, source, AV select, etc.)
If your TV set is not supplied with a video input only a coax cable input, you will need an RF Modulator which can be purchased at any Best Buy, Radio Shack, Wal-mart, etc. You will also need a small coax jumper (3 to 6 foot should do it), and a set of RCA cables (Yellow, Red, White) as described above. The RF Modulator comes with instructions on how to connect it. It has a coax input, RCA input and a coax output that will connect to your TV set.
I hope this helps. Cheers.
Feb 09, 2010 | Televison & Video
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
1995 honda accord car stereo wiring. Factory stereo stollen, all I got are the stripped wires. Which cable is what?
1995 Honda Accord Stereo Wiring Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 11, 2009 | 1995 Honda Accord
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
29 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
