Question about Sharp Microwave Ovens
Sharp microwave R305hw won't shut off when plugged in. Off Cancel button and Start buttons don't engage and the carousel turns and the fan runs but no heat is generated when powered on. Only solution to shut off is to unplug unit. Situation began randomly a couple of days ago.
  • Sharp Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 02, 2008
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
I unplugged my aunt's microwave to clean it, when I plugged it back on the light inside is on and the plate turns and the fan goes, cannot do anything with it, can't cancel or start, only way is...
Likely when you cleaned it, grease mixed with the cleaner you used got between the button panel and the actual button switch behind the panel, making it stick on. Will need the model to determine how to remove the panel to clean underneath...OR, it may dry out and start working normally again.
Nov 03, 2017 | Frigidaire FMV145K Microwave Oven
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Sharp R-520KS - When the door is opened, the light and fan comes on and the carousel rotates. I don't know if microwaves are emitted. How can I stop the fan from coming on and the carousel from...
You can tell if microwaves are being emitted if you get warm standing in front of it (seriously). But I wouldn't recommend that unless you want to cook yourself.
First thing that comes to mind is the door interlocks are out of adjustment or bad. Home microwave ovens are not supposed to operate like that. Some commercial models start the fan right away and run it after the cooking cycle is completed but I've never heard of a consumer model that does that.
Find your closest servicer here and have them take a look.
Sep 04, 2011 | Sharp R-520KS Microwave Oven
Sharp 2010 turns itself on, fan runs but does not microwave
The repair or replace decision depends to some extent upon age and repair history.
Oct 04, 2017 | Sharp R-1210 Microwave Oven
Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Oct 14, 2009 | Sharp Microwave Ovens
Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Sep 28, 2009 | Sharp R-1480 Microwave Oven
Sharp Carousel 2 Microwave start switch broken
Hi George,
I ahve the same issue. Did you manage to repair it or did you need replacement?
If repaired then how?
if replaced then where did you manage to get the part from?
Regards
Vipin
Jun 04, 2009 | Sharp R-1870 Convection/Microwave Oven
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Microwave Ovens Logo
181 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
