Question about Sony STR-DA2ES 6.1 Channels Receiver
Receiver issue My Sony DA 2ES receiver just clicks and beeps on and off. Won't respond at all...even when I pull the plug and turn back on ..it just clicks? Any help on any possible fix? thank you..
  • Paul Teichmann May 11, 2010
    Need some clarification here. Off the top of my head I would say that it had detected a problem and the protection circuit is kicking in (possibly the clicking sound you hear) and preventing more damage. When you say "beeps on and off", can you be more specific? Do you mean that it beeps then turns itself off? Is there a light labeled "protection" or over and if so, does it come on when the unit clicks? When is the clicking occuring? Any info you could add would be helpful.
2 Suggested Answers
SOURCE: Sony V444ES Receiver
Ours started doing this also now up to 20 min of clicking before it turns on.  My thought is that it is a bad power supply since once its on it works fine.
Posted on Aug 04, 2008
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
Sony dsc-tx66 does not respond
here's a solution: http://www.squidoo.com/sony-tx66
Jul 23, 2012 | Sony DSCTX66 - Dsctx66
1980 Suzuki Gs450L won't start. I stalled out pretty bad in 4th gear and it won't start back up after. Bike won't even crank over, just makes a clicking noise. Any ideas?
pull the plugs then crank motor you may find one cylinder full of gas and that will keep it from cranking, if it cranks without the plugs allow it to dry for a bit , make sure plugs are dry then install and hopefully GO!
Jul 04, 2012 | Suzuki Motorcycles
How do you reset your PS3
you hold da power botton n leave it press youll here 1 beap the sec. after it will shut back down. once it shuts down let go of da power botton then 2 once again you press n hold it down youll here da 1st beep sec. after youll here 2 beeps dats when u release it n itll request you 2 plug in the usb n control aswell follow da instruction n it will direct you 2 a menu dat has options of restarting system, tile restoration, rebuild database, ect.
Dec 06, 2011 | Sony Playstation 3 (PS3) Console
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at thomas.faust@dishnetwork.com. Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
Hard drive not responding, comes up with message restore hard drive. when you do this the message just comes back.
Wendy.
Breathe. :)
Now, hold the power button down until the system turns on and turns back off.
Now, then let the button go. Then hold the button down again it will beep once then beep twice quickly. Then let it go. It will tell you to plug in the usb cord and connect the controller then press the ps button.
A menu will apear - select option #5 (System Restore).
Simply AGREE with everything it tells you until completed. You will need to reset the time and date on the unit, but this should correct the issue.
Nov 03, 2010 | Sony Playstation 3 (PS3) Console
I have a sony xplod gt200 The truck is a 1999 Dodge Dakota R/T The deck beeps as I scroll through the menus and volume controls but will not play music in AUX, TUNER or CD. But I get Beeps. Thi sis...
the beeping can be turned off for AUX to have sound u need to have something hooked to it if there is no sound it could be blown or incorrectly connected speakers or even a blown fuse also try RESETTING the unit
Oct 13, 2010 | Sony XPLOD CDX-GT200 CD Player
Player won`t read
turn console onto standby and leave a min
then hold button in till it beeps 3 times and release
then do this again it will beep 3 times last one being double quick beep
a menu should appear
click on the one that says files this will restore your lens reader
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Insignia nsr2000 on/off problem.
had the same problem... turns out the copper on my red and black speaker wire (on the speaker, not receiver end) was touching - causing my receiver to go to standby (self-preservation probably lol). i pulled the wires further apart so the copper ends weren't touching and that solved it.
Jan 20, 2009 | Insignia 200W Stereo Receiver
Sony STR-DA2ES 6.1 Channels Receiver Logo
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
