Question about Whirlpool Duet GHW9150P Front Load Washer
Error F02 I had an error code of F02 come up on the machine. The door is locked and it sounds like the pump is running. I have unplugged the machine several times. How do I take off the panel to check the pump? Are there other problems?
  • 5,911 Answers
"F02" is a Long Drain error. You are right to assume you need to check the drain pump as this is usually the cause. The following link explains the error code and what to check for:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If you perform all the preliminary checks and the error code persists, try unplugging the washer for at least 30 minutes to reset the computer. Sometimes, this will clear some fault codes.
Keep in mind, a running pump does not always mean a working pump. If anything was lodged in the pump for extended periods, the pump impeller and/or motor may have been damaged. It is recommended by the manufacturer to replace the pump if the error code will not go away. The next link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
A replacement pump can be ordered on line at searspartsdirect.com. Just type in your model number and locate item number 10 under the "Pump and Motor Parts" heading.
I'm not saying your pump is bad. I'm giving you this information in the event that it is. I hope this helps you. If you have questions, please let me know.
Posted on Sep 02, 2008
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 23, 2012 | KitchenAid KHWV01RSS
Keep getting f02 code and check all drain hoses and the pump for debris and the filter and still keeps getting the code and the pumps sounds like it is runnning or just humming
unplug the machine f02 is something is caught in your hose or your pump or your drain line F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced once again please message me back if you have any further questions and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Kenmore Elite 45986 Front Load Washer
My whirlpool duet frequently locks up. It flashes f02 or SUD or just sits and does nothing. Sometimes it takes over an hour for a 40min cycle. Today I used the washing machine cleaner in it on the...
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Got an f 02 message, now the door is locked and will not open. Have unplugged and then plugged in again, still locked and cannot unlock and need to get clothes out. What is an F 02 error?
F01 refers to Long Drain Error.
Reason -
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
What Needs to be Done -
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 13, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore front loader fluctuates between FDL F11 and F02 and only runs for a few min at a time
Hi There
Here's some of them you can read to read. Hope this helps you.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
F/02 Long Drain
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Take your time reading this i hope it helps you out.
Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Washing Machines
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After f02 code came up ran a test and get c00 andhttp://www.fixya
4. Check the drain pump filter for foreign objects.
Sep 27, 2009 | Kenmore Washing Machines
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
106 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
