Question about KitchenAid KSRG22FK Side by Side Refrigerator
8 year old Kitchenaid not cooling
We have a Kitchenaid side by side. The compressor was replaced two years ago and now seems to be dying again. The fridge section is 50 degrees, the freezer is 50 at the top and 20 at the bottom.
We have a radiant heat floor-could this be causing the unit to overwork itself? If so, is there anything that can be done?
    Genius:
  • 2,920 Answers
The floor has no control over the fridgr or the way it works.you said its 8 years old youve already replaced the compressor once so maybe it time for e new fridge.
Posted on Sep 01, 2008
Strange tapping noise
forget about using youtube try googling it and see if u can get help? not sure but the compressor has a seal that separates the coolant from the oil and when it goes or starts to leak u may get weird sounds? sorry cannot help more Ive heard clicking sounds before from the compressor but it was usually due to bad relay having to do with the starting process
Feb 19, 2015 | KitchenAid Refrigerators
Have power but compressor no work
Tried unplug,replug it back in half or an hour later.Most of the time the the compressor will reset and kick in than it work again.This is a temp solution only,because most of the compressors in frig have this intermittent problems will died again because of over heat the design 24/7 plugin doesn't help especially continue of power to it.Replaced the frig if it more than ten years or replaced the compressor if less.
Sep 04, 2013 | KitchenAid KSCS25IN Side by Side...
Hello, I have a Kitchenaid Superba KSRB25FHSS02 side by side refrigerator. It was made in 1999 and came with the house. Two years ago, the compressor went on it and we had it replaced. A couple days ago,...
It's really up to you, to decide whether you want your refrigerator to be fix or replaced and buy a new one. You need to calculate the cost between repair cost and the price of a new refrigerator. Which one is suited your budget plus the convenient of the trouble free unit for many years to come.
Since your refrigerator is about 12 years old already and it's undergo several repair, including the most expensive compressor replacement. I think it's economical to spend for a brand new unit.
New unit have service warranty of about one year, it will take many years before it undergo service repair if you use and treat it with proper care.
Good luck on your decision.
Jul 03, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Our 2-year old Whirlpool side by side refrigerator is not cooling. Cooling power seems to have been reduced over a couple of days as it didn't die suddenly. Initially the compressor wasn't going. A...
ONLY THING I CAN TELL YOU NOW IS THERE IS A LEAK SOME WHERE IN THE SYSTEM. AND I M SURE THE NEVR DID ANY LEAK CHECK ON THE SYSTEM IF YOU DO NOT WANT TONGET AN OTHER REFRIGERATOR; TRY GET A REPAIREMAN WITH EXPERIENCE AND HAVE GOOD TESTER EQUIPMENTS
Oct 24, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Both fridge and freezer do not cool
check your relay on your compressor ,unplug unit and take relay off and shake it.it is probaly trash.
Aug 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
KitenAid KSRX25F -- HOT FRONT FRAME
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
Aug 01, 2009 | KitchenAid KSCS25IN Side by Side...
KitchenAid side by side KSRE25F not working
id get rid of it personally its at least 9 years old and it sounds like the compressor may be out on it its your call
Jun 27, 2008 | KitchenAid KSRG22FK Side by Side...
Kitchenaid freezer will not stay frozen 5 years old
it might be your thermostat stucking up...the one your adjusting one notch higher...
Mar 28, 2008 | Refrigerators
Refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Jun 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRG22FK Side by Side Refrigerator Logo
181 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
