Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Monster 1200 steam cleaner
How is the best way to use this steam cleaner in the bathroom, for the toilet, tub and sink?
I need assistance w/ the monster 1200 steam cleaner
No steam created with power light on
Sounds like your heater is shot. Probably needs replacing.
Dec 03, 2014 | Euroflex Monster SC60 Multi-Surface Steam...
I need the Monster 1200 Manual
Do a web search for the manufacturer and model and usually they will have this information available for download there.
Oct 05, 2014 | Euro-Flex Monster 1200 Handheld Steam...
Refill water tank
With the unit unplugged push down the steam lever and hold while pushing down and turning the cap..
Dec 25, 2013 | Euro-Flex Monster 1200 Handheld Steam...
Euroflex ez2 stop working
Minerals in the water clog up the steam outlet tube on these units. You have to open the unit and look for the outlet from the steam generator and try to unclog with a wire.
...Ummm is there water in the unit (just asking) :)
Nov 21, 2013 | Euroflex Monster Ez2 Steam Cleaner
My steamer gets hot but no steam if very little is coming out what do i do
clean it with lime away where the steam comes out it has had hard water build up that has clogged your openings
Apr 06, 2012 | Euro-Flex Monster 1200 Handheld Steam...
Cannot remove cap that is used to fill monster steamer cleaner
Press the Water tank cap and Unscrew it to the empty water tank. (Page 7)
Manual is at the link below.
LINK
Hope I was help.
Mar 28, 2011 | Euro-Flex Monster 1200 Handheld Steam...
My steamer spits out water but not steam
It sounds like you may have mineral buildup in the system. You can try filling the water tank 2/3 with water and then filling it with white vinegar. Steam until the tank is empty. This should clean the buildup out of the machine.
By the way, Rather than just running the vinegar/water out, this solution is good for bathrooms, kitchens, sinks, showers, and windows.
Feb 26, 2011 | Scunci 900 Handheld Steam Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
388 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
