Question about Vacuums
Is there anyplace online that I can buy a replacement cord winder for a electrolux lux9000 vacuum?
  • 99 Answers
Model no. req??????????????
Posted on Oct 11, 2008
How to fix retractable power cord
this can be tricky and dangerous if you are not familiar.The cord winder had a metal coil system that spins very fast.Sometime people pull the cord too far out causing the coil to seize.To get to the winder slide off the "Electrolux" slide off[located on the sides of the vacuum] Your best bet is to take it to a vacuum repair shop.Before trying anything take a flat screw driver and puch it in the hole where the cord comes out and push it in,sometimes this fixes the problem sorry I cant tell you more as it is hard to explain the procedure....Please be careful.
Feb 08, 2015 | Electrolux Epic 6500 Vacuum
How to replace electolux 7000 cord
These canisters are not easy to change the cord in. If you're somewhat handy and know how to disassemble the machine, it is more cost effective to just order a cord winder complete assembly and switch them out yourself! It's most likely less expensive than the labor and parts you'd pay to have it completed! I have them! Hope it helps! Thanks!
Aug 26, 2014 | Electrolux Vacuums
Why electrolux pwr cord will not stay out?
The locking mechanism inside the cord winder is defective and needs repaired or replaced. Hope that helps!
Apr 23, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux vacuum ergospace stop working how to fix
I am not too familiar with this particular model but I would think the cord winder may be shorting out. I think you can take it apart by turning it on its side, pull the side strips off. It is a bit tricky but if you access the winder check the electrical conitinuity from the winder to the plug in cord. You are probably better to take it in but if you cant please be careful to not get a shock..
Jan 16, 2014 | Electrolux EL4100A Ergospace Cannister...
I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
May 24, 2011 | Electrolux Guardian Bagged Canister Vacuum
We bought a new cord winder for our Electrolux 1205 Canister Vacuum cleaner and we are trying to install it is not turning on. We get it all connected but it doesn't turn on. Is there a reset button or...
Did you put a bag in the vacuum?
I suspect there's an improper wire connection somewhere, but there are other things that could cause this I strongly recommend taking it to an authorized Aerus Electrolux dealer and letting a trained tech check it out.
http://www.aerushome.com/storelocator/
Mar 21, 2011 | Electrolux Vacuums
CORD SPOOL WILL NOT PULL BACK
Try tilting the vacuum to about a 45 degree angle. Gently tug and release the cord a few times. This usually will release the cord. If not, the cord winder may have broken, or the spring came loose, and it needs replaced/repaired. Take it to the nearest Aerus Electrolux store for help/repair.
Jan 19, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Broke cord reel on Lux Ren.
The only way is to replace the cord winder assembly.
Feb 20, 2010 | Electrolux Guardian Bagged Canister Vacuum
Electrolux el6985 cord brake does not hold how do
you have to replace the cord winder. Since eureka bought out electrolux their product quality has really went down the drain.
Jan 02, 2010 | Electrolux Harmony Canister Vacuum -...
How do you access and then repair the cord winder on an electrolux canister vacuum cleaner?
Is it the long type, 2 wheels on the back, one swivel wheel on front?
Aug 02, 2008 | Electrolux Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
