Question about Philips 46PP9302 46" Rear Projection Television
Shuts off automatically, like 1-2 sec after turning on
About 1-2 seconds after turning the thing on, it goes off. What on earth causes that? If anyone has any ideas, I"m totally open for suggestions.
  • oleggok Sep 21, 2008
    When I turn the tv on, yellow light stays on for about 30 seconds. then it starts flushing, then tv turns iself off. It started ti behave this way after I had a power surge in the house. I am thinking may be it's a fuse ?
  • Steve Allison
    Steve Allison May 11, 2010
    Is the cooling fan running?
    If not, the set may be designed to shut down after a few seconds to protect itself (and you).
  • Philips Master
  • 8,617 Answers
Your set is a rear projection it doesnt have a cooling fan, but does the led blink a certain amount of times? If so that is an error code and can be used to help diagnose your problem.
Posted on Sep 01, 2008
I turn my Apple Ipad on and select a game...30 seconds later it shuts down
Make sure your battery is fully charged or just run with a power cord. Also, the battery could be bad.
Dec 05, 2017 | Apple Cell Phones
My GE dryer GFDN110EL0WW when turned on runs for 5 sec. Then cuts out after about 15 secs. It will automatically start again. And will continue this cycle until I turn the unit off.
Dear Kevin.
I surely hope you do not already know this!
Dryers today have a whole bunch of shut-offs.
Specifically, a fuse or two and several thermostats, any of which will cause your symptoms.
The most likely cause is air tubes clogged with lint, which the lint trap does not catch.
The fix should be to take the whole machine apart and clean the whole thing.
You may find as much as a shoe-box full of lint inside.
That lint has caused one of the fuses or thermostats to shut off the machine before it catches fire.
God bless your efforts.
Jul 30, 2017 | GE Dryers
Dryer starts then stops 10 seconds later for 1 minute then starts again
You dryer has several "overheat thermostats" located at various places inside your machine.
They are to prevent fires caused by overheating.
I suspect one of them is defective, or you have another problem which is causing one to shut your dryer off.
The dryer is shutting off to prevent a fire.
Be blessed
Feb 08, 2013 | LG DLE2532W Electric Dryer
Turn on and screen goes blank after 45 seconds
I found the problem was related to the lamp. Your TV power up but then the lamp would overheat and automatically shut down (audio and video) resulting in a dark screen with no sound. Once the lamp cooled (30 - 60 secs) it would come back on. Then overheat, turn off - recycling "eternally". A new lamp will solve the problem
Bye
Dec 28, 2009 | Sony KV-35S45 35" TV
Everytime i turn on my tv it will shut down automatically in 2 sec.
when i turn on my tv it displays red colour then it goes off after 2 sec
Dec 17, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Same thing
More Info please, it will usually go to standby if camera turned off or after the meter shuts down after a predetermined time (nikon default setting in camera is usually 6 secs.).
So if you switch camera back on or push shutter release to wake up metering system flash should automatically come out of standby.
Or you can push the on / off button for approx 1 / 2 secs. this will wake it up , then turn it off. Hope this may help Ian
Aug 08, 2009 | Nikon Speedlight SB-600 TTL Flash
Shuts off after 23 seconds....
In most cases when the microwave stops @ 23 seconds it's the Magnetron which has failed, and is shorting to earth.
Either that or the magnetron isn't getting the right signal from the inverter board. It gives it 20 seconds to get the right signal or it shuts itself off.
Apr 04, 2009 | Panasonic Microwave Ovens
Television Shuts Off
TRY REPLACING THE REGULATOR OR CHECK DIODES IN SAID CIRCUIT ,ALSO CHECK FOR BAD CONNECTIONS.
Jan 26, 2008 | Toshiba MD14FN1 14 in. TV/DVD Combo
Philips 46PP9302 46" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
