New HD TV from Best Buy--Last one--discon. model--no book or clicker--can`t get set up--3 trip back to BB with no help??
Ended up returning TV to Best Buy for full credit and purchased a new in box set and now have it up and running. Thanks for the follow-up and please do not charge my AX card!! Terry U.
Posted on Sep 03, 2008
What is the cost for replacing screen for KDL-32CX523
usually the cost to replace a screen is more than a new TV set! I'd say its time for a new TV set. Either recycle your old set or toss it on Craigslist as a parts set. Someone will buy it! If I have helped,
please sign my guest book.
Jun 08, 2014 | Televison & Video
Hey guys i gave my ps3 to a shop in st neots to get my hd working and he blew out all the dust with a air gun and changed the settings and said the ps3 is set up for hd now and it worked on the shop tv but...
When changing the display mode of the PS3 you must be in the correct mode and be using the correct wire. If in the shop it was last set up in HD mode, then you must be using an HD cable (component cable(wire with red/yellow/white) will not work. Also, make sure that your TV can handle the resolution it is set in. If your TV at best handles 720p and the PS3 is set in 1080, then you will have to hook it up to a TV with 1080 to change it back or you will not get a picture.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
The gate opener is elite will this opener open the gat or do I need a different model?
Thanks for using fixya.
The clicker manual does not list this as a device it is compatible with. I would not think it would as a regular security plus remote or 315 remotes do not. I would buy a passport remote. You can find these at Thanks BB
Aug 25, 2010 | Chamberlain Clicker Universal Remote...
I have a 40 inch Samsung TV which I've had about 3 years (sorry I Don't have the model number handy). I have DirectTV and an HD-DVR. The HD Channels were great up until about a few weeks ago. Now sometimes...
If your menus on the TV and other inputs look good then it is probably a resolution setting on your Directv box that needs to be changed. To get HD it needs to be set at 720p or 1080i. Please take a moment to rate my answer. Thanks....
Dec 02, 2009 | Televison & Video
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Broken RCA D52W20 & Best Buy
any board you get for this set will be refurbished if you want your tv fixed then let them put the part in, if you refuse the service then I expect your contract will be no good anyway.
Oct 08, 2009 | Televison & Video
My ps3 doest display anything nor makes any sounds please help
Just a gander, but your PS3 may be set for HD output thus not displaying on your non HD television, your best bet in this case is to find an HD television, friend, coworker, etc, connect to it and switch the settings back to regular. Also if I understand correctly leaving the ps3 completely unplugged for 72 hours may also reset all settings. Good luck!
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
Can I set the default input?
some tv model has a setting that every time you switch on the tv the set will back on the last customer setting, other tv does not support this setting. But if your tv works as i mentioned earlier during the first time you buy it. Meaning the IC memory is malfuntion.
Jun 14, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Westinghouse LTV-27w7 HD TV, two yrs old, blueish square flashing on & off, no picture.
if you have warranty work they will direct you to the service center you will need, I do not know of any bb that service tv's.
May 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
GE tv shuts itself off
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 27, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
