Question about Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive
My Toshiba Satellite A30-203 has a black screen\ Display problem
I have a Toshiba Satellite A30-203 and the screen fades almost to black, like it is in the hibernate mode - you can barely read what is on the screen. When you tap the pin that sticks up above the keyboard on the right side (that pushes down when you close the lid) the screen will usually come back to full brightness - usually for a second or two - sometimes for a couple of hours.
I changed the software settings to "never" for the hibernate mode, for all occasions, including when the lid is closed, thinking the pin above the keyboard was the problem, but that didn't change anything.
Has anyone else had this problem. or does anyone have any idea of what is broken or defective.
Thanks in advance:)
Cant't boot- Black screen- permanente message Says: System pool\system32\config\sofyware\or its log or alternateis corrupt, absent or not rerwritable.?????
  • 1 more comment
  • Anonymous Nov 27, 2008
    my screen blacks
  • obwangaz Jan 16, 2009
    when i put on my laptop i am able to view what am working on for like 30 minutes then the screen goes blank with some lines on it. however i can still use a desk top monitor to see what i am working on
  • ojaybuka Feb 06, 2009
    I have a Toshiba Satellite Pro A30 and the desk top screen never keeps it picture. For everytime I change the desktop picture, the entire screen turnes black. Besides that, it is working fine.
Jai un probleme avec mon micro portable je possede les pilotes de la carte graphique ati radeom mobility 9000 aidez moi svp à trouver la solution merci
Posted on Sep 22, 2008
  • wahidrabdi
    wahidrabdi Sep 22, 2008
    i have a problem with driver graphic card of my coputer satellite a 30 (radeom mobility 9000) soved me svp.
Bnn
Posted on Sep 02, 2008
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
My screen looks like a photo negative..I have a Toshiba Satellite.
Right click on your Desktop, click on Properties, then go to the Settings tab and set the color to 32 bit True Color.
It sounds to me like your display settings are set to monochrome/black and white.
Best Regards,
James
Jul 21, 2009 | Computers & Internet
My Toshiba Satellite M305D-S4830's screen will flicker black randomly with no aggrevating and occasionally will fade to white or black completly.
I recommend you to reinstall the display drivers of your laptop as the issue may occur due to the corrupted display drivers.
Uninstall the display drivers from Device Manager.
Expand Display devices.
Right click on the display device and select Uninstall.
On restarting the laptop, windows will detect the device and reinstall the display drivers.
You can even install the display drivers from your notebook support website:
www.csd.toshiba.com
Jun 29, 2009 | Toshiba Satellite M305D-S4828 NoteBook AMD...
White lines and fade desktop icons on screen
The LCD screen is at fault. If your lappy is in warranty try replacing it. It would cost araound $50-$80
Thank you!
Sabharish
Jun 01, 2009 | Toshiba Satellite M30X-S181ST Laptop
My toshiba satelite L-35 screen fade to black and
The LCD ribbon convector is loose or damaged or the LCD is damaged
Apr 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Lcd Screen has issues.
i dont know but i would think using the screen from a different computer would not be good.
im sorry but you will have to buy a new one. there is no way to make the fade stop.
Dec 31, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Screen black out?
Most likely the LCD inverter. The inverter supplies the voltage to the ccfl lamps to light the display. These inverters run about $20 on e-bay.
On my toshiba M105 the problem is the Tab welds at the top of the lcd itself. 1/3 of the screen is not usable but an external screen is perfect.
Apr 14, 2008 | HP Pavilion dv6000z Notebook
Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive Logo
753 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
