Question about Epson PhotoPC 800 Digital Camera
My picture is too light (overexposed). - Epson PhotoPC 800 Digital Camera
    Master:
  • 542 Answers
If you're using the forced flash setting, it may be too bright. Try setting the flash to Auto. If you're facing a bright light source, you may need to shoot your picture from a different angle. Use Image Expert to adjust the picture's brightness, as described on page 9-4. Set user mode to Manual and adjust the camera's exposure setting.
Posted on Sep 13, 2005
SOURCE:
Camera makes overexposed pictures wiht lines can this be a software problem ?
Nope, this is a hardware problem and the camera needs to be worked on. Notice how your display works fine but the finished product exhibits the anomaly. The recording end is messed up.
Aug 12, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
My Canon IXUS 120IS has developed some problem. All the shots are overexposed. I have tried all different setting but still the shots are coming overexposed. IS it a problem with the settings or hardware...
Check the ISO setting...is it too high for the lighting conditions? Check the "exposure compensation"....it should be at "0". If you want darker pictures, you can set it to a lower number.
Jan 14, 2011 | Cameras
Pictures look overexposed
Hello
the best way to avoid these lighting problems is to adjust your aperture settings, your shutter speed and your film speed when shooting.
for more information visit this site
http://www.photoshopsupport.com/tutorials/jennifer/fix-overexposed.html
Good luck
Dec 07, 2010 | Casio Cameras
We have a canon powershot A410 digital camera with 3.2 mega pixels (purchased brand new in fall 2007) and recently, whenever we take pictures outside, they come out completely white (overexposed). The...
Hi there its a chance of sersor damaged. He not able to read the light. Thats why outside image are over exposed. I suggest you visit service center for check or repair the lens sensor.Thanks.
Apr 07, 2010 | Canon PowerShot A410 Digital Camera
Overexposed pictures
usually all the digital cameras have a filter to diminishes the quantity of light passed through objective. This filter is enabled by a small relay and that relay is powered by a mobile wire from the mother board. Because this wire are always moved every time when the zoom is used ,this action can cause the interruption of that wire.
The second possibility is that relay to get stuck and can`t be able to switch the filter.
Sep 15, 2009 | Canon PowerShot A460 Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Overexposed highlights
Normally the problem is simply that the pictures are slightly overexposed. Despite all the fancy names manufacturers stick on their metering systems, the camera doesn't know what you're taking a picture of. They basically strive to make the entire scene a medium gray. As a result, some highlights may be blown out, just as some shadows may drop out. Generally, dropped shadows are more acceptable than blown highlights.
If a picture is really important, bracket. Take one shot at the metered exposure, then another a stop under (and perhaps one a stop over, if you're feeling paranoid). It was common for a National Geographic photographer to spend an entire roll on one shot, trying different light angles and exposures. After all, film is far cheaper than air fare and hotel rooms.
One advantage of shooting digital is that you can see the results immediately, and correct for blown out highlights.
Nov 11, 2008 | Contax 167 MT 35mm SLR Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Overexposed picture
My guess is the the EV setting is on the + side and not neutral (0). Either that or Image Adjustment setting is wrong. Check EV by pressing the +/- button (right side near On/Off switch). Hold EV selector and make sure 0.0 is in the display. Let me know if that is not the problem and I'll assist you further.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Mar 18, 2008 | Nikon Coolpix 5700 Digital Camera
Epson PhotoPC 800 Digital Camera Logo
184 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
