Question about Sub-Zero 680 / F
Sub Zero Model 680 - Light in Fridge and Control Panel out
Sub zero model 680 - Frezzer section seems to work fine. Ligt was going on and off in the fridge section. Light now off and control panel off. Fridge side still keeping food cold, though.
  • 1 more comment
  • Anonymous Jan 29, 2009
    Light in the fridge section is sometimes on and sometimes off. It now is mostlly off. I tested the bulbs with a continuity tester and they tested fine. Could the switch be the problem?
  • guest Aug 29, 2013
    Try and replace the light bulb. Subzero control panels are dark and appear to be broken when light bulb is dead.
  • Maro Uiz Medeiros
    Maro Uiz Medeiros Dec 09, 2013
    TEMPERATURE IN THE FRIDGE IS 5.0C MOTOR WORKING ONLY THIS LIGHT IS FLAX IN SIDE OF THE FRIDGE . HAVE GREEN LIGHT INDICATE TMPERTURE BUT STILL HAVE THE RED LIGHT IN THE BOTON OF THE PAINEL FLAX ON AND OFF
  • 3 Answers
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Posted on Mar 04, 2012
  • 1 more comment
  • sweettrea407
    sweettrea407 Apr 06, 2012
    I wiggled the switch on the left and the light and control panel light came on immediately. Saved us time and money. Thank you very much!
  • sweettrea407
    I did exactly that. I wiggled the left switch and the fridge light and electronic control panel light also turned on. Saved us time and money. Thank you very much!
  • CA Homeowner Sep 02, 2013
    Same here, but I have to wiggle the switch several times every time I open the door. As a homeowner, how do I replace the switch? I tried to remove old one but could not figure how... Thanks much.
  • 3 Answers
Lights in fridge and control panel went out. 2 switches at the top of a Model 680. Wiggled the left one back and forth and all the lights came on! Thank you whoever you are that put up the answer!
Posted on Jun 01, 2012
  • Glenn Apr 12, 2014
    The switch to the light is above the doors. Eventually wiggling did not help anymore so I just replaced the switch. If you have a screwdriver you can do it too. Remove the protective panel, then unscrew the switch, unplug, replace, then put everything back. 10 minute job. EZ.
Replace door switch
Posted on Sep 03, 2008
My sub zero 600 series has no light in fridge nor on control panel
There will be two switches per compartment, one is the fan switch, the other is for the lights... Remove the top compartment vent panel, the switches will be accessed from above... remove the wires and push them down into the fridge... you can test them by setting a meter to "continuity" test and pressing the paddle of the switch to see if it lets current through.
SUB-ZERO machines are more serial number dependent when ordering parts... http://www.midwestdistributing.com/Store/OpenPages/ManualPage.aspx?PageTitle=MANUALS
Aug 20, 2016 | Sub-Zero 632 / S
Sub zero lights not working
Probably a bad light switch. Would need some more info to say for sure though. Model? in the fridge or freezer section?
Dec 02, 2013 | Sub-Zero Refrigerators
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero 650/s control board light is out and inside lights out but fridge works.
On this model, the lights work with the light switch, if it stick all the light in that section will not work. Parts number 7014646 (about 20 bucks) If only the control display is not illuminated then the bulb behind the control is the only problem.
I hope this helps.
Oct 02, 2013 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 680/F The fridge is flashing "service"
Not filter but condenser coil thathe is next to compressor. Clean it out then check unit operation
Jan 26, 2018 | Sub-Zero 680 / F
Fridge says "service"
In the link below has several really good articles that explain how to diaganose the cold control most common and evapoarotr on you Sub Zero refrigerator. Under refrigerator videos there are a couple Sub Zero Refrigerator repair videos.
http://www.appliancerepairlesson.com/category/refrigerator-category/
Good luck with your repair, were here to help you.
Mar 05, 2011 | Sub-Zero 680 / F
Sub Zero model 680 F, inside ref area seems damp. Food also has moisture in ref section.
the air should be dry and packages not wet . I would think the defrost cycle is not working properly . may have a drain pluged or a defrost timer that is not supplying the power or the defrost terminator is cycling off at too low a tempt . . most common would be the terminator . . ck the drain and replace the terminator . there is also a drain heater that can be install if you find that to be the problem .. ..and when doing all these things clean the cond coil up on top where the fan cools the compresor . very imporant. mm
Aug 12, 2010 | Sub-Zero 680 / F
Refridgerator light out, panel out, freezer fine
It's probably the swtich (the one on the left at the top of the door opening).
Sep 25, 2009 | Sub-Zero 680 / F
Sub Zero 680 freezer temperature problem
check the condencer on top .open the doors look up you should see three screws take them out and pull down the panel and clean the condencer if its clean CALL repair guy!
Jul 24, 2009 | Sub-Zero 680 / F
Refrig lights go on and off intermittently when opening and closing refrig door
check door light switch with ohmmeter. Check for melted insulation near light "terminator". Look for wiring diagram in ziplock behind compressor grille. Second switch at door turns compressor off when door opened. I had these problems with a 695 which I would assume is probably similar in design.
Dec 26, 2007 | Sub-Zero 680 / F
Refrigerators Logo
1,878 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
