Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
DVD How can I burn images from my Ixus 75 to DVD so that they can be shown on a TV screen.
  • 56 Answers
One of the Best program to do this with is the Cyberlink Power Producer, I use it a bit and it is Excellent.
Here is the link to the website sadly it is not a free program:
http://www.cyberlink.com/multi/products/main_3_ENU.html
Cheers
Emmanuel
Posted on Sep 11, 2008
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
There are marks on my LCD 42" TV ,its on the screen itself.It looks like water marks.It started of small marks and it then it getting bigger.
Things You'll Need:
  • Burn-In Reduction Screen Saver DVD
  • DVD Player
  1. Instructions
    • 1 Plug DVD player into your TV and power on. Make sure you plug the right component cables into their corresponding inputs on the back of the TV. This is usually done by simply matching the colors of ends of the cables with the colors of the input holes on the back of the TV.
    • 2 Turn TV to the proper input to display the DVD. Make sure there is not a DVD in the player.
    • 3 Place burn-in reduction screen saver DVD in the player. Allow a few seconds for the DVD to start playing. A pattern of white "video snow" will appear on your screen. The entire screen should be taken up with this patterm.
    • 4 Run the DVD for at least several hours; this will help wear the TVs phosphors evenly. Depending on how long the image has been burned into the screen, the amount of time you should play the DVD varies a lot. A good rule to follow would be to play the DVD at least four times the period the image has been displayed. If you have an image that has been on the screen two hours a day for a whole month, run the screen saver for at least 240 hours
Jan 17, 2011 | Televison & Video
Westinghouse HD Flat Screen 1080Pure TV - Shadows
Image burn can be permanent if the image was left on for a long period of time. You can try a pure white screen to balance the screen out. They sell DVDs online that have white screen and other screen correcting images to try an correct the damage done to your panel. here is one linked plasma or LCD both can burn.
best of luck
Thanks
Roety
Jul 14, 2010 | Televison & Video
Can we use canon ixus 75 as a webcam
A raw image is an uncompressed format your camera takes the picture in. Usually it gets transferred from the camera into a .jpg compressed format to your computer (which simplifies everything and is able to be viewed by anything like photo viewers). I would search for a canon IXUs 75 driver for your computer, and turn your camera 'on' plugged in with your USB using a standard computer photoviewer program to see if it has a live mode?
Jun 18, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Data stamp
There won't be...you can only get the date on the pic when you use POSTCARD setting.
Another suggestion would be to buy a Selphy printer from canon, and then you can select to have the date on the print.
Aug 16, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
IXUS 75 LCD screen
Hi
Google: Darntoothysam com, then search for 'sd750' and you will find the LCD as well as a replacement service.
Good luck with your repair.
Thomas
Jul 19, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Battery display on canon ixus 75
Its same for everyone. You can only see the battery when its about to run out. IN that case a red flashing icon appears on the upper right corner of the screen otherwise there is no indicator for ixus 75.
Jun 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Nothing on the screen
Did you accindentally hit the "DISP" button (bottom button on the right side) ?
Feb 15, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
IXUS 75 has blank LCD screen
A screen fails in one of two ways. 1.Backlight goes- If looked at closely or to one side the images are there as ghosts but not illuminiated. 2. Connector or board component has failed which could mean with a back light Okay a brilliant white screen. Failure 1 - nothing for you to do there Failure two -if it is a connector- gently flexing the camera casing in the region of the base of the screen may elicit a reconnect. In either case however- I think you will find that unless it is under warranty or insured in some way- New camera will be a more economical approach. But check out makers support site first.
Aug 17, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
