Question about Frigidaire ATF6000ES Front Load Washer
Loud - maybe ball bearings gone
Makes a lot of noise and won't tumble. Think bearings may be shot.
  • Anonymous Dec 16, 2008
    my problem is am concerned that the noise from the machine isnt the bearings. is there a silencer built into machines and if not how can you tell if its bearings or glides?
    do ppl get fobbed off with this quite often, only my client is disabled and on low income. Would glides be infact cheaper but the engineer will make more money if he says it is bearings
  • Anonymous Mar 23, 2014
    Ball bearings need to be changed.
  • 166 Answers
How old is the machine?
There are glides that the drum turns on that may be bad rather than a bearing!
How old is the machine? if it's 9 years old or more.Do not put good money into bad!
A new machine will save you a lot of money on energy. Enough to pay for it self in only a few years!
Posted on Sep 07, 2008
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
My abs light keeps coming on and off. My brakes make this loud noise and the petal just goes down on it's on. They say it is wheel bearings. But I don't see ho
Hello there:
i dont think that the wheel bearings would do this
however if your rotors are shot and the pads are gone than this is in need of replacement dont wait get it repaired asap this is a safety ssue ok
best regards mike
Aug 18, 2009 | 2002 Suzuki XL-7
Winding noise and vibration when driving on front right tire
you could have more than one problem the vibration accelrating maybe an inner cv joint ,if you just had the tires replace and an aligment done they should have checked the front end for worn out ball joint and tierods but the wheel bearing may not have any movment but can still make noise
Jul 13, 2009 | 2003 Kia Sedona
Dryer heats up but drum doesn't turn.
If the drum is very stiff to turn could be the drum bearings shot which would account for the broken belt, replace belt and it liable to break shortly after again. hover are known for there bad bearings and they cost a small fortune.
check it out have a look and see if there is nothing jaming the drum inside, i am certain your belt has gone and maybe down to the stiff drum making belt break, replace belt but bare in mind it may break again if the drum is too stiff.
choice is yours really. bearing kits cost more than 50 quid in general
Jul 10, 2009 | Hoover Dryers
Drum making sqeaky noise
The squeak is the rear bearing mount rubbing on the hanger ball. The plastic bearing is gone and that metal piece is cutting a groove into the ball mount. I have a picture. If the ball will be cut off and the drum will fall into the heating element and the belt will break. Not good!
8a3a785.jpgTo get to this bearing you must pop the top and get the belt loose,lift out the drum and inspect the bearing. The kit is fairly reasonable.This is something that a DIYer can easily handle.
May 11, 2009 | Frigidaire Electric Dryer
Loud whinning noise then no picture or sound
Color wheel is the noise you are hearing. It can also keep the lamp from firing up if it has seized up. Remove the lamp and inspect it. Replace the color wheel for sure.
Jan 10, 2009 | Samsung HL-R5678W 56" Television
Loud noise duing spin
not advisable lots of work and costly if your not used to it.Get a new appliance
Nov 13, 2008 | Zanussi FJS1225W Front Load Washer
Our Neptune Maytag Washer is making a very loud noise during the spin clycle. I think It may be a bearing but its only a little over 4 years old. Have Maytag had a lot of problems with this kind of noise
Yes Maytag has had seal and bearing issues. Check your original warranty paperwork it still maybe covered?
Call the store where you bought it, they may cover it under warranty.
Did you buy an extended warranty?
May 04, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
90 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
