Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Lens Problem I have a C-8080 and I like it but I'm not sure if it is working 100%. The lens barrel is sloppy from side to side and clunks slightly when moving it quickly. It has been that way since it was new. It has some issues with auto focus as well. It has a hard time focusing on clouds and soft objects at infinity. I called Olympus when I bought the camera and mentioned the sloppy lens barrel and they told me that that is the way there made. It is slow to focus when going from close objects to far away objects. I just would like to know if this is my camera or all C-8080s. Thanks
    Sergeant:
  • 255 Answers
The lens play is normal. The focus is not the fastest, which is a shame because the camera powers up instantly! There are techniques to minimize the focus lag if you choose to keep the camera (e.g. hyperfocal; pre-focus w/manual focus lock). Its a great lens, but like every other camera it has its drawbacks. I suggest using it a bit more before you make any final decisions. Good luck and happy shooting!
Posted on Sep 13, 2005
    Sergeant:
  • 255 Answers
Mine was exactly the same. They seem to work fine, just give the camera time to focus. After a while, I tired of the slow pace of the C8080 and sold it, moved on to the Konica Minolta A2 which is a much more responsive camera. I've since pretty much stopped using it too: the Pentax *ist DS DSLR is a near perfect fit for the photography I love to do and works the way I want a camera to.
I've dropped my Canon Power Shot SD960 IS with the lens out, and now the outer lens is tilted at an angle and wedged tight and the barrel of the zoom will not retract. I've tried turning it off and on,...
Try this first, power off and gently push the lens barrel sideways - not back in!, If the barrel and the lens move slightly, you will get it working after some more manipulation in the same way. If it does not budge, sorry to mention this but your camera sustained more damage and you cannot do do much on your own.
Aug 14, 2013 | Canon PowerShot SD960 IS Digital Camera
The lens are stuck out and the camera seem like its coming on but doesnt...Its a DSC-W170 Model
Take your camera and carefully look at the lens side of it. Does the lens look slightly out of center. Sort of pointing very slightly the wrong way. If it is you've given the lens a knock while it's been extended and put the complete lens barrel out of alignment. Please don't try what I've seen touted around the Net and bash the camera lens down on a table, this will make the whole thing completely unusable. The camera needs stripping down completely and the lens either realigned or worse, completely replaced.
The other problem it could be is a piece of grit or sand jammed between the lens elements or the lens and the camera body. Again a strip down job to free the jam.
Just make sure the batteries are at full charge and in good condition if they are getting a bit old try a brand new set of High quality alkalines and see if things start moving then. Quite often the camera may switch on but simply doesn't have enough power to drive the lens. Try the batteries first, you could save a packet.
Apr 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom
Lens probably got off its track. you need to take the front case apart and pull out the 3 lugs at the base of the outer lens. YOu should ba able to manage to get the outer lens off, dont worry about breakin git as the stuff is made of heavy plastic. If you get it off, see if the inner barrel rotates smoothly. YOu will be actig on a small motor so youll feel a little resistance, but it should be fairly easy to rotate. Lube the helical tracks with heavy white lithium grease and put the outer lens back on making sure to align the tracks, press the lugs back in and reassemble. worth a shot. I did mine and was successful. See my folder on the C8080 http://picasaweb.google.com/pishta68/8080lens/photo#5199141246863292738
Apr 24, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Camera
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Jan 17, 2008 | Polaroid I533P Digital Camera
Makes 3 beeping sounds then turns off
what happen if you put another memory card in it?
Dec 02, 2007 | Polaroid I533P Digital Camera
Lens stuck
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Nov 26, 2007 | Polaroid I533P Digital Camera
The lens is stuck out
Oct 20, 2007 | Polaroid I533P Digital Camera
Lens is broken
Oct 03, 2007 | Polaroid I533P Digital Camera
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
79 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
