Question about Sharp AR-M162 All-In-One Laser Printer
Sharp AR-M162 Power saving mode
Is there any way of turning off the power saving on this machine?
Every time we want to photo copy a page we push the button and have to wait for 30 sec for the machine to warm up.
When it does copy it will regulary jam or feed two pages from tray.
Seems to be a very porly designed machine
  • 23 Answers
Yes there is a way to turnoff the power save feature.The answer is in the manual.
Using the round navigation "button" its blue scroll down to key operator hit enter and key in all oooooo zeros.
hit enter scroll down again to energy saving and hit enter set all the minuteds up to the maximum of 240 thats 4 hours of non power saving running time, if you make a copy during that period it will wait another 4 hours to go to sleep.
the reason it misfeeds so much is that you probably lost the green stopper at the bottom of the paper pile, also the side things as well as the metal corners have to cover the corners of the paper at a 45 degree angle , because thats what seperates the sheets.
I service over 300 of these and they can be very reliable if the guy fixing them knows what to do.
Posted on Oct 30, 2008
Do I have to call a service
it means fuser temperature is abnormally low, check halogen bulb works , then check thermistor, and thermostat ,
Jul 24, 2014 | Sharp AR-M162 Toner Cartridge ARM162...
Sharp AR-m162 is printing from my computer but refuses to scan to the computer. It worked fine yesterday.
Run Sharpdesk network scan tool. in low right of your taskbar click on network scan tool
create a profile in profile tab, This will show up on sharp display as an avaiable location to scan to.you can choose where to scan to and what program if any to open when recieving a scan. Next in scanners tab click "auto detect" it will find available sharp scanners on the network. check one you want to use in the box in the list click "ok" close it make sure it is running in the task bar and add it to startup if need be but you should be good to go after this
David
Nov 13, 2017 | Sharp AR-M162 All-In-One Laser Printer
Code F2-04 solution
http://www.retrevo.com/support/Sharp-AR-M162-Multifunction-Printers-manual/id/600ag113/t/2/
Above is your user manual below is your service manual.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-162,+AR-163,+AR-201,+AR-206,+AR-207,+AR-F201
http://www.eserviceinfo.com/fulltext.php?search_ft=DPX-7010MD
You have a sensor error. I have included your user and service manuals so you can attend to the error.
F1-04 Bin limit position sensor error in sorter
Aug 12, 2010 | Sharp AR-M162 All-In-One Laser Printer
Blank copies on my sharp ar m162
you are either out of toner or the scanner lamp on the glass table is blown...
Dec 29, 2009 | Sharp AR-207 Copier
New Sharp AR-M162 won't print
Remove all the tape from the unit. there should be no tape, plastic, foam etc on the unit. After removing packing and tape reinstall and power cycle machine.
Hope that helps
TankMurdock
Apr 27, 2009 | Sharp AR-M162E Black and White Copier
U2-40
Push P * C* in quick succession to enter simulation mode. Once there, enter 16 on the keypad. push the print button (like making a copy). Push 1 for yes then print button again. push the CA button. Copier should reboot and run fine for you.
Apr 01, 2009 | Sharp AR-M237 Copier
Create fax from my HP window vista computer to Sharp AR-M162
Won't work with Vista unless you spend $100 for some fax program
Feb 20, 2009 | Sharp AR-M162 All-In-One Laser Printer
Sharp AR-5132 blank copy
see comments, loose blade by roller, push in, fixed
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
"maintenance needed" after so many copies
I hate this machine. Right now I can't print. It tells me to change the tray when I try to print.
Mar 13, 2008 | Sharp AR-M162 All-In-One Laser Printer
Sharp AR-M162 All-In-One Laser Printer Logo
184 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
