Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Memory card blocked!!
Everytime i insert a different memory card to my camera it says: "Card Locked" i tried unlocking the card by moving the switch but it still doesnt work,i think it got something to do with the camera,Help me plz!!! i bought a new camera, and kept my old memory card. it took photos, but then the other day i was looking at them and all the photos have vanished.
i did not delete them, the screen went blank and when it came back on all the photos were gone..
i took it back to boots and the man said it was because when i got the camera i never formatted it to suit my memory card. what can i do
  • 374 Answers
First of all with a Casio camera Casio will only guarantee the camera to work with Panasonic, Toshiba and Sandisc memory cards. If it is not one of those three brands I would go buy one of those brands. Make sure you format your memory card with the camera before using it for the first time. As for the other memory card try using a program like cardrecovery.com and see if you can still pull your pictures off that card. I bet they are still there. :)
Posted on Sep 10, 2008
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Memory card error locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Does moving the switch make and difference?
Aug 19, 2013 | Canon PowerShot A610 Digital Camera
My canon power shot A2000 IS says the card is locked, how do I unlock it
The card insert has a tiny tab - you must move it to the unlocked position. You may need to use a magnifying glass it is so tiny. You don't mention the memory card you're using - different brands use different types of tabs - some are on the back - some on the side - some counter sunk.
Look close
Gary @ Fix Ya.
Jul 10, 2011 | Canon Powershot A2000 IS Digital Camera
Memory card error it says card is locked I slid the switch back an forth but still says memory card
I'll include a diagram of the little lock switch so you know the correct position to be able to load pictures to it. Another reason for getting the card locked error is if the memory card hasn't been formatted in the camera it's being used in. Formatting is necessary after downloading pictures to the computer as well.
Diagram
Mar 02, 2011 | Canon Cameras
Inserted 4 GB memory card. new camera trying to take a pic and I keep getting the message card protected.
Memory cards particularly SD or SDHC have an option to protect the files from accidentally deletion. This is done by moving the small part of the memory card to the 'lock or unlock' position. Try to look for this small switch on the side of your memory card.
Dec 26, 2010 | Vivitar ViviCam 35 Digital Camera
Sd card locked
Perhaps it is!
Look on the left side of the SD card and move the lever up to the top Write protect OFF down is on.Sometimes when inserting a card the lever catches and moves slightly off the top posotion and is then read as locked.
Sep 15, 2009 | Sanyo Xacti VPC-S60 Digital Camera
Hp photosmart that keeps saying card locked when inserted
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Mar 17, 2009 | HP Photosmart M447 Digital Camera - Silver...
Memory card error/card locked
It sounds like your card is locked. You need to unlock it. On one of the sides you should see a piece that can move back and forth. Move it from the position it is now to the other side. This should unlock your card. When locked the files are unaccessible to anyone. This also means that files on the SD card cannot be deleted while the switch is in lock position. When the switch is in up-position, then all files located on the card are accessible to anyone, and that files may be deleted from the card.
Good Luck.
Apr 07, 2008 | Canon PowerShot A570 IS Digital Camera
I have the same exact problem with my camera and NOTHING works. Bought a new card, didn't work. Checked and rechecked the card to make sure it isn't locked...didn't work. I have no solution for you but to tell you you are not alone with this problem and it isn't your card or the little slider on your card. It is within the camera.
Jan 24, 2008 | HP Photosmart M425 Digital Camera
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
96 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
