Question about Astar LTV-3001 Television
Light colored smoke comes from top of TV when first turned on
We have our TV in a box for about eighteen months...never used it until today. When I turned on the power switch, smoke comes out the top of the back panel and disappears when the power is turned off. Any suggestions? Thanks,
If it's like my problem with this set, the power supply gets really hot and essentially melts all of the contact cement they smear all over the PCB to keep things from coming loose. That didn't affect the set's performance and ceased after just the first few minutes out of the box. But recently, we had the same thing happen and I found that all four of 3300uf caps on the board had cooked-off, All of them were swelled and two of them had sprayed their liquid contents around their enclosure, creating the smoke.
I replaced all four of those, but the set will still not power up. I'm getting 120vac all over the "Hot" side of the board and nothing on the "Cold" side. How do I test the three PC817 optocouplers that separate the two sides of the board?
Posted on Sep 20, 2008
Picture problems with a Sony 61" RP
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Aug 19, 2012 | Sony KP-61HS30 TV
Remove and inspect the lamp first to make sure it is not shattered--color wheel faces it and can cause this problem also--set monitors the speed and if wheel not running or running too slow it will shut down the set.
Look at wheel to make sure it is intact---some of them do come apart and pieces will be missing.
Jun 09, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
LNT5265F when first turned on new, small red light came on, played a little tune, then picture came on. About 7 months ago, after the tune played the picture didn't come on, the red light would go...
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board...
If the capacitors is faulty your TV turn on after a lot of attempt until the TV is totally turn on...
In that case you need to replace the bad capacitors on the power supply..
How can you find where is the faulty capacitors? The bad capacitors is usually leak/bulged on top in that case you easily find it through visual check...
Sep 10, 2011 | Samsung Televison & Video
K-Tec Champ HP-3 Burning Smell and Light Smoke
That burning smell is kind of a death sentence. At least a switch or more likely coils are burnt out.
Mar 27, 2010 | K-Tec Champ HP3 Work Top Blender
The screen is turning light blue along the edges
Sorry, but its wearing out so soon,,, I have a similar one that turned green in the right top corner which was temp solved by not having all my accessories that were plugged in turned on at the same time,,, but after a few months the green became permit and the tv stopped functioning. Hope a solution comes your way, but to start looking for a new one as repairs are = and or more than a new television. Good Luck Rkaler24
Mar 18, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Horizontal lines and color problems?
this could be a format issue. When you change the channel do the lines go away ? If so try to go into the cable box (assuming you have a cable box) and reset your formats and exclude the format causing the lines.Make sure if your using component cables all colors match up.If this does not fix it replace your component cables/hdmi.All else fails unplug your TV wait 5 min. and plug it back in. Hope this works for you.
Jul 08, 2009 | Dynex DX-LCD32-09 LCD TV
Top up tv+ digital tv stopped working.
i had same prob, tried unplugging three times
then unpluuged for 5mins
, plugged back in left it alone, ie didnt touch remote or front panel, until it settled down ~15mins, green light came on (doesn't normally)
and everthing seems ok now
May 03, 2009 | Televison & Video
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Astar LTV-3001 Television Logo
110 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
