Question about JVC Everio Share Station DVD Burner Burner
Incompatible Disc Message
Help. Keep getting Incompatible Disc message when trying to copy. Using the correct discs. Don't know what the problem is. Hard drive is full on camera. Desperately trying to copy so that we can clear it and continue to make new memories! HELP PLEASE.
  • 4 more comments
  • Anonymous Oct 02, 2008
    EXACT THE SAME!!!!
    What can we do?  I have read and followed the instructions.
    I have never gotten it to work at all.
    I am livid.
  • Anonymous Nov 12, 2008
    Yup, same problem as everyone else. Bought it about a year and a half ago and burned some DVDs with no problems. Then when I recently tried to use it (with the same Sony DVDs that had no problems before), kept getting the incompatible disk error message. Very frustrating, and a complete rip off.
  • kray19 Dec 08, 2008
    My burner recomends TDK DVD-R but they are unrecognizable.
  • Anonymous Dec 14, 2008
    bught about a year ago. worked fine until a month ago. will not burn to any disc. what is the solution?
  • chaplinme Dec 18, 2008
    incompatible disk i am using dvd-r this sucks
  • elsing4 Dec 19, 2008
    I am using all forms of dvd disk and non of them work. How do we contact JVC or Sanyo???
You need to use -R DVD disks, I used Maxell 1.4X speed disks wih no problem in a CU-VD10 berner. Hope this helps
Posted on Oct 11, 2008
Keep getting "Target Overflow" error message, even
you may have a bad ROM. If you have a multiple target unit, switch the source from the ROM to one of writers and try copying that way, if it copies then it confirms that the ROM is defective.
If you have a Single target unit, check your master disc under disc info, depending on which controller you have it should be under utility or disc info. Once in disc info it should tell you the size of your master disc, for DVD-R it should be under 4488MB, for DVD+R it should be under 4482MB. Then double check the master in the PC just to confirm.
Jun 12, 2011 | EZ Dupe EZDupe Two Target DVD Duplicator...
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
123CopyDVD.exe has stopped working......
First, Uninstall your program using Add/Remove Program in Control Panel.
Start Menu -> Control Panel -> Add/Remove Programs
Note: Be aware of shared files don't remove them, it will affect other programs that use that file
After Uninstall, restart your computer
Then start again, proceed to installation of your program.
Jan 26, 2010 | Navarre 123 Copy Dvd Gold for PC
Trying to hookup new Aqous led/lcd 40 in to sony blu ray disc home theater system. Get incompatible audio signal message on tv
incompatible... hmm sounds like you're not using the correct Cables, are you using DVI or standard rca?
Oct 04, 2009 | Sharp Televison & Video
When trying to copy a CD, I get the following error message: Warning - Bad Master Disc!
I assume it means just what it says. The Disc you are trying to copy is faulty?
Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
Char S.
May 27, 2009 | LG 1 to 6 Target CD Duplicator 52x CDRW...
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Error message - incompatible disc
I BUT A JVC EVERIO BURNER AND I CANT BURN MY VIDEOS FILES I insert the Disc in the Burner, it tries to recognize the disc and then comes up with , DISC ERROR CHANGE DISK
Jan 29, 2008 | JVC CU-VD10
JVC Everio Share Station DVD Burner Burner Logo
396 people viewed this question
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Kim Halliwell
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
