Question about Dell Axim X5 Pocket PC
Charging Axim while travelling
What is the best system for charging axim while travelling? Is it necessary to take along the charger, can you buy a second charger?
    Master:
  • 852 Answers
Do you mean another besides the A/C adapter? This is separate from the cradle (option), so you can take it with you together with the travel synch cable (option). Although Dell guides says to use no other chargers then the A/C adapter provided, this can be impractical in some situations. The spec on the charger is as follows. I suppose providing you meet this, you should be OK with a Auto or Lighter type adapter. Do so at your own risk.
Posted on Sep 13, 2005
I have a dell axim pda that I hadn't used for awhile. I charged it and saw green light, but when disconnected charger the light went out and still can't turn on. Purchased new battery and sa
LCD cable is loose inside, need to be opened up and reseated or replaced, or replace main board, if under warranty call DELL support to request onsite tech to repair.
Sep 29, 2017 | Dell Axim X30 Pocket PC
What if my new backup battery for my dell axim x3 wont charge
Usually a good indication that either A. the battery is bad even though you just purchased it or B. the battery is non compatible with the charger.
Jan 11, 2011 | Dell Axim X3 Pocket PC
My dell axim does not charge a new battery- I tried 2 new ones.
check the charging unit or the plug on ure phone,it mite be loose and not charging
Sep 24, 2009 | Dell Axim X50 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
When charging my axim X30 on the cradle, the on-off light is blinking from green light to amber consistantly... when I remove the device from cradle the device does not turn on at all.. I have replaced the...
It sounds to me that your "original" battery, the one that causes the blinking when charging is completly drained dead, causing it to show an error by blinking the light.
I have one of these PDA's and have never had that problem, I also have a larger battery as well, and it works great. I suggest recycling the other battery, and possibly purchasing another larger one for back up,
Mar 27, 2009 | Dell Axim X30 Pocket PC
Power button flashing
Clean the battery connectors on both sides, so on your Axim and on your battery.
Also try to push the battery against the connectors, maybe put a sheet of paper between it or so.
Mar 28, 2008 | Dell Axim X50v Pocket PC
Axim X50 locked up during boot up process
May have to do a factory reset on your device.
Nov 02, 2017 | Dell Axim X50 Pocket PC
USB Sync Cable
I dont' think so. No other PDA does - it would be quite a drain on the USB port. It isn't like powering the tiny LED in an optical mouse.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
62 people viewed this question
Clive
Clive
Alun Cox
