Question about Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 1022 all-in-one error code sc542
Copier was siezed form leaseing co.c bouhgt back 1 week later.
now on power up i get error code sc542. please point me in the right direction.
Thanks Jeff Gordon
  • Anonymous Mar 19, 2014
    Shook the copier to find the spring and now I have a CO 07
  • Ricoh Master
  • 2,794 Answers
Fusing temperature warm-up error
The fusing temperature does not reach
the standby temperature within 20
seconds after the main switch is turned
on.
• Fusing thermistor defective or out of
position
• Fusing lamp open
• Fusing thermostat open
• Power supply board defective
• Poor connection of the fusing unit
It could need a new thermistor
Posted on Sep 03, 2008
    New Friend:
  • 32 Answers
Clean thermistor leak of toner waste drop to fixing roller clean lower upper check also thermostat and rset error
Posted on Jan 28, 2016
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
My copier nashua africio 1022 is showing error sc542 and cant work
1. Press the Clear Mode key. (yellow key)
2. Use the keypad to enter "107".
3. Hold down Clear/Stop for at least 5 seconds.
4. Enter Copy SP mode
5. Exit.
6 turn off machine then after 5 seconds on the machine.
if problem exist again replace thermistors then repeat the above simulation 1 to 6
Aug 19, 2011 | Ricoh Aficio 1035 Copier
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
the reset should be all you need...
reset link
Feb 08, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
My ricoh 1022 after puting power on it shows error code sc542
What code? Try entering service mode then turn off copier and turn it back on. (push these buttons in sequence Clear modes (yellow) 1 0 7 then hold the red stop button for 5 or so seconds you are now in test mode
Jun 10, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Funcional problem code SC542
Hello sir; Follow the steps to reset;
1, press "clear mode", "107", then press and hold "clear/stop" key untill display change.
2, enter 5810, then press "execute" on screen, then press "close".
3, turn power off then back on, it will go back to normal.
Apr 28, 2009 | Ricoh Aficio 1018D Copier
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
1,100 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
